27WON Front Strut Tower Bar
xjoshuax89
Josh
Maryland
Averia
Arco, ID
2018 Civic Si Sedan
I swapped out the Si battery and metal tray for the the Type R battery and metal tray along with the they type- R grounding cable. Which version do I need to buy?
Thusee
Thusee
Markham
2018 civic si sedan
Whats the difference in batteries?
Averia
Arco, ID
2018 Civic Si Sedan
I believe it can. You need the metal shelf, the plastic tray that sits in the metal shelf, the longer ground wire, the tie down and one of the rods to hold the tie down. There is also a black plastic surround for the battery. I did a side by side schematic comparison to determine what PNs were different. The tray ships with a foam insert which is also sold as a separate part
Vincent@27WON
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Type R version.
Drake
Honda Civic Si
Did you find that the brake brace had a noticeable improvement or effect?
Tough to say since I haven't been to a track and the placebo effect may be at play, but for the few times I have had to brake late before a stoplight the car felt more firm and stable while coming to a sudden stop
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
You will notice it the most on track for sure.
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
For everyday street driving does the brace translate into any noticeable improved pedal feel? Or is it really only when your braking hard like on a track?
Mostly hard in track.
