Myx
- Mar 6, 2016
- 79
- 2,166
- 2,042
- Delaware
- 2018 Honda Civic EX (Hatchback/CVT)
- Vehicle Showcase
Mods
-27WON turbo
-PRL cold air intake race maf
-PRL intercooler
-PRL catless downpipe
-PLM front pipe (I don't recommend this with the PRL downpipe)
-Modified type r exhaust (removed the 2 inch restriction where it connects to the frontpipe)
-Vit-tuned flex fuel kit
-PTP turbo blanket
-Ktuner v2
-Custom tune from Derek Robinson
-92 octane with 37-38% ethanol
-FX350 with stock flywheel
Notes
I had Derek limit the low end torque.
From my conversations with Derek, I think this is about as far as you can go with the base model motor. My fuel system is maxed out. (The Si fuel system can deliver more fuel than the base model.)
He had also mentioned the base model turbo inlet pipe might be a restriction vs the Si.
I made 241whp and 303 torque on this same dyno with the stock turbo, running the same fuel with PRL street maf, PRL intercooler, stock downpipe/front pipe, and exhaust on a custom Vit-tune.
Nice numbers! Thanks for posting your before/after numbers. I STILL would like to be able to change the turbo inlet to a larger size but it is what it is.
On the Front Pipe situation, I had the same issue and made a thread about it. I later found out that it was installed wrong and several people did the same thing. PRL may have changed and include instructions on how to install that front pipe properly.
Your before numbers are VERY interesting as I'm only interested in a taking the stock torque up to 240-250 range tops. And to notice that with your before mods your max hp rpm moved from 5500rpm to 5000rpm. Good to know!
