27WON Civic Turbo Upgrade now available!!!!!!!
incutebus
K
FR-S, 21 Mk5 3.0 Supra, Lexus F-Sport
I have some ideas of what is actually going on. If you're testing on Tuesday he may want to get those logs to me tomorrow so I can give him some pointers ahead of time!
Map switching for Si was released at the end of last month, but you should double check with the tuner if changing any boost levels will negatively effect his tune!
I'll follow up with Daniel on Monday and go from there. Thanks for the awesome support!
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
They're in testing afaik. They will eventually release one.
But with so many options (DP, FP, exhaust, etc...) you're better off with a custom tune. I mean you're already spending the big money on a new turbo, you should factor in a tune as part of the cost...
airickmatthews
Ruskin fl
17 civic hatch sport
I already installed the w1 the other night. Thinking the ktuner base map was sufficient enough. I’ve already paid for the etune with Derrick, just haven’t had that started yet due to waiting on installing my clutch. You guys think the ktuner basemap is safe enough for the time being? As long as I don’t get on it. Knock control is steady at .49, IAT1 and 2 are within -5 and +5, AFR is running around 14.9. I emailed two step performance about getting the tune started, just not sure how long till that can happen.
AsianGuy98
2017 Civic Si Sedan
It should be good enougb if you dont beat the shit out it. Also Derek Robinson doesn't work for TSP he has his own shop IMW. I was on the 23psi basemap for a couple of weeks without any hiccups then got Etuned by Derek
airickmatthews
Ruskin fl
Ok awesome! That’s what I wanted to know. Haven’t even gone about 4k while driving with the new turbo yet. Figured it needs a good break in. I know he doesn’t work for TSP, but they were offering their flex fuel kit with a custom tune from him, so I purchased that.
AsianGuy98
2017 Civic Si Sedan
That TSP Stage 2 is for the stock turbo I believe.
airickmatthews
Ruskin fl
Oh okay, thats what I had for a couple weeks before Etune. FBO, flex fuel FX350 running on the dual 19psi/23psi with flex fuel enabled.
Yea those are all the mods I have as well. SPEC 2+ with steel flywheel showed up yesterday in the mail. Was going to install that, break it in, then tune. But started second guessing myself if the w1 was safe enough to daily with just the ktuner basemap. Wasn’t sure if I should get a tune before the clutch to make sure I wasn’t harming anything.
AsianGuy98
2017 Civic Si Sedan
You should be good as long as you dont WOT.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
The data we've received running our KTuner basemaps with the W1 suggest it is perfectly safe and nets more top end power than the factory turbo. Si maps are being released, non-Si will come in the near future!
Vincent@27WON
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
So does @KTuner have a base map for the w1?
Ones for the SI are dropping this week. And then @KTuner will work on the non-si as mentioned above. Good stuff heading your guy's way to make the most out of the W1 safely and reliably.
