27WON BBK - ANY PHOTOS OF INSTALLED KITS
stephenmeadows
stephenmeadows
StephenMeadows
Stephen
United Kingdom
Honda Civic Sport 1.5T 2018 Hatchback (European Spec)
sorry I know this is a brake thread but wheels on the bottom are just too sexy to not ask what wheels are those and size/offset
I can't help with these wheels but my 27WON BBK is complimented by these lovely Titan7's!.......
Honda Civic 10th gen 27WON BBK - ANY PHOTOS OF INSTALLED KITS 911498A5-B041-4FA4-8A02-A3AFDECFD09E
PEPSIFLAME
Dallas, TX
2020 Honda Civic EX Hatchback
I have an SPG hatch that I'm going to do the red ones on. It'll blend nicely with the red splitters (front, rear, and sides) I'm putting on.
Thusee
Thusee
Markham
2018 civic si sedan
Heres my 27won bbk with 2 sets of wheels with summer and winter. Yes I'm using I'm bbk in winter and its holding up pretty great!
Spec:
Work Emotion Cr Kiwami Dark Matt Bronze
18x9.5+38
Tires:
Firestone Indy 500 with 245/40r18
Honda Civic 10th gen 27WON BBK - ANY PHOTOS OF INSTALLED KITS 20191020_212603
Spec:
Super Advan Sa3r
17x7+30
Tires:
Firestone Winterforce215/50r17
Honda Civic 10th gen 27WON BBK - ANY PHOTOS OF INSTALLED KITS 20200204_201504
arpypat
Spec:
18x9.5+38
Tires:
Spec:
Super Advan Sa3r
17x7+30
Tires:
Did you have a lot of clearance with the 9.5 +38 work wheels? And do you have any rub with that wheel/tire setup?
I'm considering the 27won BBK in the future and also really like those Work wheels, but I was looking at 18x8.5 +30 or 18x8.5 +38 if that can clear the calipers.
As much as I would love to throw on a 9.5" +38 wheel, the thought of 31mm of poke is kind of scary on a lowerer car!
Thusee
Thusee
Markham
2018 civic si sedan
Yes I have lots of clearance. I have very little rub on the front but only on extremely hard dips.
I need to do an alignment to set my front camber to eliminate the rub completely.
The amount of rub will depend on your drop/offset/tire size.
arpypat
Thanks for your response! I'm not going to be as low as you are in that pic. Just got Ktuned springs for my Si, so might be at 1-1.25" lower all around after they settle. I don't want anything too aggresive for the wheels, so I guess I'll look for a rim design that has spokes for a BBK!
Deleted member 32006
Sorry to revive old thread but did you use spacers with the 9.5 +38 to achieve clearance?
Thusee
Thusee
Markham
2018 civic si sedan
No spacers needed.
If you already have the wheels then print out the template 27won has on their site. And do a test with that. It will show you any clearance issues if you have with whatever wheels you chose.
I'm against using wheel spacers.
Thusee
Thusee
Markham
2018 civic si sedan
Why's that?
Slip on spacers take away needed threads for lugs.
So a 5mm spacer will have 5mm less stud for the lugs to grab.
Bolt on spacers are safer yes as long as its hub centric. Also if the build quality isn't good the spacer can be defective. Also adds stress to bearings. Minimum bolt on spacer would be a 20mm as 15mm the studs hit the wheel I believe. So then In turn you'll be looking at wheels with high offsets.
Using extended studs with slip on spacers can work but not a lot of people go that route.
I have always preferred buying wheels with the right offset rather than using spacers.
These are my opinions, others may say otherwise.
