Chi_The_Process
- Feb 24, 2019
- 18
- 95
- 67
- Minneapolis
- 2019 Honda Civic Type R
Quick review of @27WON
Overall product:
This mount is significantly beefier than the stock motor mount. The mount has a poly insert on the motor side and a fixed non poly on the chassis side.
Install:
The removal of the stock motor mount was extremely easy. I had watched multiple videos on how to install the aftermarket motor mount. Some things that were missing as a quick tip. After removing the stock mount. The motor drops a few millimeters. This slight drop made it impossible to install the 27 WON mount without a struggle. Key advice, take a low profile jack and jack up the motor just a hair. This would would you line up both end points on the motor mount.
Initial reaction:
The very first start up WOW! The car VNH sounded like I had installed 3 inch catless straight exhaust. On a scale of 1-10, the cabin noise went from 0 on stock to 10+ with this mount. You can feel the vibration through your seat, steering wheel, and dash. You can also see the hood vibrate at a stop! The initial drive, anything over 5k sounded like was shooting a Desert Eagle. The buzzing and drone effect was almost unbearable. I did a hard pull of the line and the wheel hop was definitely smoother/non-existent. The second gear pull was way smoother than stock.
I only have 50 miles on it right now and it definitely improved over the initial VNH! Even with the windows down and music off. I can’t hear the wastegate anymore.
Overall product:
Install:
Initial reaction:
