255 or 245
Digity
Jason
Norcal
2018 Hatchback Sport-16 Pilot-90 K5 Blazer
Anyone have pics from behind running either of these tires on 18’s
Also if you post pic can you mention 35 or 40 on the 255’s. Thanks
Vic_L
Victor
British Columbia, Canada
245/40/R18
18x9 +40 wheels
EDIT
Damn, thought I had a picture from the rear looking forward...nope.
I just have one from the side of the car looking back.
(I'll need to snap a rear to front shot later)
Rear passenger door, looking back to rear wheel.
Front side marking looking back at the front wheel.
neonjed
Augusta, GA
2018 Civic
I know 245/40's will fit fine but I ended up ordering Continental tires in 235/40 size from 4wheelonline. My wheels are 18x9.5". Will post a picture next time.
Digity
Jason
Norcal
  • #5
zspeed
Camden County, NJ
What wheel and size/offset is that l liked the way it sets
245/40/18. Wheel spec 18x8.5 +44mm offset with 5mm wheel spacer. Should have used a 35 series profile for the tires instead.
Vic_L
Victor
245/40/R18 gives you closer to stock 235/40/R18 in overall size, diameter, and speedo rating.
245/35/R18 you would be off by a bit more.
If you upsize to 255 width, 255/35/R18 would be give you close to stock.
shan0mak
Shane
Buffalo, NY
2019 Civic Hatch EX
Sorry to dig this up. Trying to make a 245/40 vs 255/35 decision.
Is there a reason you regret the 40 aspect ratio? Thanks!
Boss002
Ryan
South Bend, IN
www.tirerack.com
2019 Civic Si Sedan, 02 Mustang GT
I don't know if I have good pictures to show how flush they are with the fender or not... I have a set of 18x8 45mm with 255/40R18 RE71R, 245/45R17 Goodyear SC3 on a 17x9 (forget the offset), and will have a set of 245 RT660s on either a 9 or 9.5 RPF1 with 45/38mm offset soon enough.
arpypat
Arpan
KC
2019 Civic Si
245/40 vs 255/35 decision will have to be made after you determine your wheel width & offset.
If you're going with 8 or 8.5 wheels and greater than +35 offset, then you should be fine with 245/40.
255/35 should really only be used on a 9" or 9.5" width wheel. And ideally you'd want these wheels to be greater than +40 offset or you may rub if you lower your car.
I just got 18x9.0 +45 wheels wrapped in 255/35 rubber that I'm going to throw on once the weather gets better. Can post pics after they are on!
shan0mak
Shane
Buffalo, NY
2019 Civic Hatch EX
Hey, thanks for the help!
I have 18x8.5” +35 wheels on the way. I’ve been leaning towards the 245/40 size (Michelin’s PS4S). I am on stock suspension on the hatch, but am considering a slight drop, like the eibach pro kit or whitelines.
arpypat
Arpan
KC
2019 Civic Si
No problem! Since you have the hatch, you should be fine with clearance with a slight drop. You could also consider 235/40 for those wheels, but It'll be a tiny stretch.
