2022 Si Clutch Swap?
Beholder84
Eric
Santaquin, UT
2019 Honda Civic Si Coupe
With the 2022 Si getting some changes to the flywheel, I'm wondering if there's going to be a better clutch involved too. Would it be a direct swap to the 10th gen, and most importantly, would it be worth it? The CTR retrofit is hard to come by, and if the 2022 is upgraded it may end up being a better option.
KOIVUN1
Steve
Chicago
2020 Si CBP
likely not since the main reason for the ctr swap was for the higher torque capacity and near oem feel. assuming honda is gonna be honda, the clutches in the genxi will likely not be any better than genx's. of course other than it being a sm flywheel instead of dmf.
tacocat
matt
2019 Civic Si coupe
Seeing as they gave the 22 less power I'm sure any changes will not be to the ability of the clutch to hold more power. That's a lot of work and money on a OEM clutch pressure plate and flywheel for very little added benefit
