2021 CTR Dashboard display question
GGinMP
GG
SF Bay Area
2021 CTR
This is probably covered somewhere before, but I couldn't find the info here or in the manual. On the 2021 CTR dashboard, there are various speedometer display options including rev redline, g-force, gas/milage info, etc. On the picture below, I'm pretty sure that selecting this option will show turbo use. Can someone tell me what the two symbols are to the left of it? Thanks!
Gansan
Glen
San Diego, CA
1999 NSX, 2018 Civic Type R
That's throttle and brakes. (See the throttle plate angled in a venturi?)
Jadohz
Christian
Orange County, Ca
2021 Civic Type R (R-42864)
Side question, how did you get your dash to display your Trip A Mileage?
GGinMP
GGinMP
GG
SF Bay Area
2021 CTR
When one presses the milage "reset" stem briefly, it rotates between full milage, trip A and trip B. Holding it in when on A or B resets that number to zero.
GGinMP
GGinMP
GG
SF Bay Area
2021 CTR
Thanks. I don't see that being used to often, but I suppose it's better than staring at the G-force read-out as I speed around tight corners!
lexro
Montreal
Civic LX 2006, Civic Sedan Sport 2019, Type R 2021
as i'm still learning the clutch and throttle response on this car, I find myself going to this display from time to time, just to see what percentage of throttle is being registered lol
lexro
Montreal
btw is it possible to customize the orders of the display? like fuel consumption in between throttle/brake and boost pressure.
Gansan
Glen
San Diego, CA
It's an interesting thing to display. It's clearly directly reading the throttle and brake pressure sensors because the gauges have no perceptible lag.
I've seen that brake symbol most often in ABS warning lights. I don't how that symbol came to mean brakes though.
@lexro Yes you can customize the order of the menu. You can also hide items you don't use. It's buried somewhere in the head unit menus.
lexro
Montreal
Get a KTuner.
Thanks, nvm then. on't intend to tune the car.
I think that's symbol for old school drum brakes.
and thanks ill check it out :)
