2020 type R license plate relocation
JohnRazic
New Jersey
2020 Civic Type R
Does anyone know how to pop off the passenger side fog light cover/garnish on the 2020 model?
Res0zsfa
Res0zsfa
Tom
Seattle
Kona N, CTR, G35 (sold), 01 s2k, 370z (sold)
Update: relocator frame does not need to be re-tightened. know that the black grill will have some scuff marks when you take out the relocator frame.
here are some side pics
Honda Civic 10th gen 2020 type R license plate relocation 4254F9C2-2E38-4C36-A472-93F78B57B332
Honda Civic 10th gen 2020 type R license plate relocation D0DDC325-6F7E-4DDF-812E-6CB98FB10644
Honda Civic 10th gen 2020 type R license plate relocation B150A633-A8F0-474A-9FE5-B0882B9BA84B
Volksparts
Dave
San Diego CA
19 CTR, 17 TRD Tacoma, 2017 Wrangler, 2020 Avalon
After copying your location I am trying to think of a different location. Seems like the plate shakes too much there.
Res0zsfa
Res0zsfa
Tom
Seattle
Let us know what route you went with. I tightened mine pretty hard and i don’t think it will be coming off. I’ll have a friend look at it while I’m driving as well
Alex_mp
Alex
Virginia
2018 civic si
Hows it been holding up?
Res0zsfa
Res0zsfa
Tom
Seattle
Still holding strong. Driven it for about 4K miles. I retightened it once because I wanted to adjust the height a bit. The last meet I went to, I saw someone with the same bracket. Highly recommend it
hondeR
Joe
Boston, Ma
2021 CW Type R
Gonna try this route on my 2021 instead of the $15 ebay bracket and zip ties I have. My plate is on secure but def not straight. Any lessons learned from install? Thanks!
Beavis
Beavis
Sacramento
2020 Honda Civic Type R
To prevent drilling holes into my front bumper I mounted my front license plate using a squared “U” bracket with nuts, bolts and washers that I picked up from my local hardware store. Mounted the squared “U” bracket to the very top honeycomb grille opening to allow as much air clearance as possible for the front intercooler. Using big washers behind the grille and squared “U” bracket created a “sandwich” type of hold.
Honda Civic 10th gen 2020 type R license plate relocation EDA5E0A1-20B8-48AE-8E7C-275B527BA74C
Honda Civic 10th gen 2020 type R license plate relocation 5280338A-CAEC-449F-BFF2-20713AC77801
Honda Civic 10th gen 2020 type R license plate relocation 98AD8B8A-7A29-45CA-B7B2-0FCFE2F0905F
Res0zsfa
Res0zsfa
Tom
Seattle
The bracket is secure and pretty solid. Try putting the horizontal metal piece on the top instead of putting it on the bottom like I did. When moving, the bar will vibrate and hit the car. I put a black foam piece to keep that from happening but even that can wear out. I’m not even sure if that even makes sense. I’ll try to snap a pic when I get back to show you what I’m talking about
Res0zsfa
Res0zsfa
Tom
Seattle
To prevent drilling holes into my front bumper I mounted my front license plate using a squared “U” bracket with nuts, bolts and washers that I picked up from my local hardware store. Mounted the squared “U” bracket to the very top honeycomb grille opening to allow as much air clearance as possible for the front radiator. Using big washers behind the grille and squared “U” bracket created a “sandwich” type of hold.
How much did the dealer charge you for those carbon hood and mirror pieces? Or are they aftermarket
Beavis
Beavis
Sacramento
It’s OEM. The carbon fiber package was included when I purchased the car from Honda.
PlayboyX
2020 BB Civic Type R , 2012 Civic Si
I saw your pictures and I recently ordered the Slybracket to try for my Boost Blue. What do you mean by putting the horizonal metal piece on top? Maybe will need a stronger adhesive to hold the bar in place to avoid any vibrations from hitting the car.
Res0zsfa
Res0zsfa
Tom
Seattle
Try installing it flipped the other way around so that black horizontal bar isn’t hitting the bumper?
Honda Civic 10th gen 2020 type R license plate relocation 5A217D20-5FCD-4047-A63D-9EDE98184CC7
TheGreekFreak
MA
'21 BB CTR, '23 SO 4Runner TRD Pro
It's so annoying they didn't make an easy access tow hook adapter integrated in the front bumper.....was so easy to install one of those screw on brackets on my GTI on the factory offset tow hook location.
Considering I do not want to cut trim pieces to run it from behind, either this or my current option (just saying fuck it and taking my chances without a front plate) seem to be the way to go. Option #2 has been working fine so far, including when speeding towards cops driving in the opposite lane face to face.
Getting the sense that with covid they don't give a shit about things like this as much as they used to, or maybe I'm just lucky with this attention magnet with no front plate, dark tinted windows, and generally going well over the speed limit.
hondeR
Joe
Boston, Ma
2021 CW Type R
Thanks Res0zsfa! I finally got around to installing and this a more robust option for me. Stuck on some thick felt where the frame would contact paint. Also zip tied the top rail to the back plate of frame so it's a bit more secure. Some pics
Honda Civic 10th gen 2020 type R license plate relocation 20210118_115611
Honda Civic 10th gen 2020 type R license plate relocation 20210118_114617
