bikejog
- Jul 17, 2016
- 10
- 1,261
- 488
- ny
- 2020 Civic Si Coupe. 2000 Honda Prelude (donated to charity).
The RS485 signal itself doesn't carry any audio data. It's all control data and perhaps also carries the vehicle speed. Connector C where RS485 is housed does carries other analog audio data (nav voices, some beeps (HU keypresses), and engine sound on 2020 Si).Does RS485 carries some audio payload (eg Navigation sounds, system beeps etc)?
If that is the case, then we need some kind of signal processing and mixing. For most people is not acceptable to discard all the audio payload that is coming from RS485. The audison remote control cannot help unless we decide to keep the OEM Amp to handle the center speaker.
Arduino (or any other SBC) idea, is promising. The difficult part will be to mix the 2 audio payloads by programming the computer. Maybe I can give it a try…
We know for sure that Axxess AXDSPX-HN3 has already managed to implement your idea.
You do not need to write any DSP code to mix in the different audio yourself. I think just get a DSP that can accept SPDIF *AND* analog (or a combination of SPDIF DSP and LC6i or such) and just feed SPDIF2 and the analog audios from Connector C into the DSP and LC6i and it will just work. Just use the remote control that came with the DSP to control the tones and volume. See my post #30 above on possible problems with echo, however.
