2020 Si Bore Size
simon_lefisch
2020 Civic Si Coupe
Hey everyone,
I just wanted to verify the bore size of the 2020 Si. I found this thread saying it is 64.1 but it was from 2015. I assume it hasn't changed but wanted to confirm as I am looking to get some new wheels in the next couple of months and want to make sure I get the correct O-rings.
Currently running stock wheels/tires but am looking at Konig Hypergram in Matte Gray, size 18x9.5 +35 offset
https://www.fitmentindustries.com/buy-wheel-offset/HG9851435G/konig-hypergram-18x95-35
Anyone have these? If so, can you post a pic of how they look? I currently have 20mm spacers on the stock wheels and they positioning is just perfect so looking for the same on the Konigs. Many thanks to all!
64.1mm is correct for the 10th gen 1.5T Civics. Not sure about FK8 Type R.
hobby-man
GTA
18x9.5 +35 is a fair bit wider. It won't be flush anymore, it'll poke. 18x8.5 +35 will be closer. My comparisons are based on an 18x8 stock wheel +50 with 20mm spacers which makes them 18x8+30.
And yes 67.1 bore for an Si.
Honda Civic 10th gen 2020 Si Bore Size Screenshot_20211015-163845_Chrome
Honda Civic 10th gen 2020 Si Bore Size Screenshot_20211015-164409_Chrome
simon_lefisch
simon_lefisch
2020 Civic Si Coupe
Thanks for info.
Unfortunately the Konigs dont come in 9" and I kind of wanted to go 9.5". With that being the case, I checked for a 30mm offset but thats not available either. I may need to look at another set of wheels if thats the case. I like how far the stocks are with the 20mm spacers so I'm trying to stick with that look. It sounds like I'll need to find a wheel that has a 30mm offset if I want to stick with 9.5" width, correct?
simon_lefisch
simon_lefisch
2020 Civic Si Coupe
For reference, here is a pic of sticks with the spacers.
Honda Civic 10th gen 2020 Si Bore Size 2990B08D-D87D-4659-9217-F6477CBDD89D
hobby-man
GTA
Thanks for info.
No, other way. If you want a 9.5 wheel you need a 45 or 50 offset.
Why do you want a 9.5 so badly? With that wide a wheel you wanna run 245 tires at minimum, 255 is ideal. Unless you're looking for a ton of stretch and exposed lip on the wheels.
If you dont want your speedo messed up too badly (within 3% error) you'd need to go 255/35R18 or 255/40R18 tires. Can't comment on if you'll have fitment issues.
Honda Civic 10th gen 2020 Si Bore Size Screenshot_20211015-192425_Chrome
simon_lefisch
simon_lefisch
2020 Civic Si Coupe
My bad, you’re right….45 offset. I was planning on going with a 255 tire anyway. Doesn’t look like the Konigs have a 45 so I time to start looking at something else….maybe the PF01’s. Gotta look around more. Thanks for the help tho, and that site is awesome btw! ?????
