2020 Civic SI Clutch slip at 2500 miles
Si Is Life
Bush1do
Civic SI 2020
So has anyone have a clutch slip so early? Im running phearable tune 1.5 PRL cobra CAI and Megan Catless downpipe after i installed my downpipe i tried to pull and to my surprise 4th gear was slipping already i only go WOT about 3600 rpm and im only on MAP 1 looks like 2020 SI clutch are more fragile than 2019 and below yrs
SHAYN3R
SHAYNE
CAMBRIDGE
2018 Civic Si
That’s too bad. I’m FBO with Phearable stage 1 with no clutch slip. Car has 100,000km on it and has been tuned since 10,000 or so. I do have a 2018, not sure if they have a different clutch in the 20s.
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
Too bad when i felt the clutch slip i tried replicating it while watching my rpm then bam i saw it jumping 4k to 6k with no pull just engine screaming lol and there is no way a downpipe will add that much torque to slip a clutch just by after installing it
SHAYN3R
SHAYNE
CAMBRIDGE
2018 Civic Si
Are you sure it was clutch slip? Was it advanced VSA kicking in
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
Ill post a video u can hear the rpm is not consistent my VSA was set at factory only
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
Share a video with your tachometer
SDAlexander8
Steve
Indianapolis, IN
clutch probably wasn’t really broken in well from the start
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
I babied the clutch till 1000 miles so i think thats good i never ride the clutch or burned it so idk it immediately slip when i installed the downpipe without it i can hit 25psi with no problem
fenix-silver
Central PA
2019 Si
The clutch is still the same as previous years. Unfortunately some people just get unlucky w/ clutch slip, like myself, since the clutch is right on the edge of being able to handle the torque from a basic tune.
SixSpeeder
East of Seattle
2020 Civic Si, 2021 Wrangler Unlimited High Altitude
My 2020 Si does not have any clutch slip. I've been tuned for around 5000 miles on Ktuner's base maps (23psi sport mode) and TSP Stage 1 Map 3. The mods that I've ran are a catted DP, frontpipe back exhaust, and an air intake. Almost no freeway miles also, but also not very many stop lights on my normal commutes. I have literally never floored it in 1st gear/hard launched the car, and rarely give it meaningful amounts of boost in 2nd gear. I generally wait for 3rd to put the power down. (I'm not implying that the OP hard launches the car, just describing my driving style on the street.)
I also did a track night at Ridge Motorsports Park but reverted back to the stock tune for it.
Si Is Life
Si Is Life
Bush1do
Civic SI 2020
Yeah thats why i thought i never launch hard too because i know it will fcked the clutch and i have an update i limited my boost at 18psi at 4th and its not slipping now i guess the downpipe gave enough gain on torque to slip the clutch at 4th gear on 22psi
SDAlexander8
Steve
Indianapolis, IN
Yeah I’m saying you never really got any good wear on it before tuned and it probably didn’t bed well.
reesee175
2017 civic sport
Yes, the downpipe does add the much torque. I refused to get a downpipe because of that reason and needed a custom tune from the problems people are having. I have fbo's minus the downpipe and seem fine. I however do have the type r retro coming as well.
fabrizzio71
Matthew
United States
2018 Civic SI Coupe White Orchid Pearl
If it makes you feel better, on my 2018 Si when it was brand new with a few hundred miles on it, I was still breaking it in and in 4th gear at about 12psi I had some clutch slip, completely stock. I was super paranoid in the beginning, and babied it for a while. I do think it’s possible to re-bed in the surface of the clutch as long as you don’t keep repeating the slip. I am now at 56,000 miles with TSP stage 1 and the clutch is ok. That being said I don’t go in map 3 ever, only 2.
There were users on here who with a downpipe on stock tune had slip. It does add significant torque down low.
