2020 civic ex offset
Dannybles
Danny
philadelphia
2020 civic hatch ex
Hello
I have a 2020 civic EX I just bought wheels from tire rack and they told me that I would have no problems however they have a 45 offset and that seems pretty big or small I guess.
these are what i ordered:
https://www.tirerack.com/wheels/enkei-performance-edr9-black-painted
Does anyone know if this will be a problem should I cancel my order?
Alphaskoom
David
DFW, Texas
2020 Civic Coupe Sport
Factory Si wheels have a +50 offset, +45 is barely further sticking out, i routinely see people here run +35 offset, which sticks out more, though i cant vouch for that number with clearance issues. I see no problem with a +45 offset, basically the closer to 0 you are, the closer to dead center the mounting surface is on the wheel when looking at it from straight ahead. Think of a 18 wheeler wheel. if the wheel is bulging out and flat on the outside, thats a positive offset, while a dished wheel, where the wheel looks like its a big bowl your looking down in, thats a negative offset.
your Backspacing is that 50 / 45 number were talking about
Honda Civic 10th gen 2020 civic ex offset 1667583779311
Dannybles
Danny
philadelphia
2020 civic hatch ex
Cool thank you I used to work at tire shops and put custom wheels on all the time and I could not remember and then when I was looking up nothing makes sense to me I think I've gotten dumber over the years but thank you for explaining explaining.
OP, your stock wheels are +45. You're 100% golden.
Dannybles
Danny
philadelphia
2020 civic hatch ex
So I got the front two wheels on they look pretty damn close to the fender like if Hit big enough bumps they were definitely hit the fenders
Honda Civic 10th gen 2020 civic ex offset 130EFC96-B94F-4176-8B3D-A5BE28F445E2
Honda Civic 10th gen 2020 civic ex offset D3587D66-DCD0-49B8-8414-277BA59E38F7
Honda Civic 10th gen 2020 civic ex offset 9C89772F-7103-4445-BA22-E89552F59FE6
Honda Civic 10th gen 2020 civic ex offset 3ED64F7E-32F5-4623-A349-A1FC3E1EF450
SethNES
Seth
Austin area
2019 Honda Civic Si Coupe
Looks same as stock to me. You'd have to get some good air to rub and probably have other concerns after such a launch. Here is completely stock on mine. Looks about same in gaps.
Honda Civic 10th gen 2020 civic ex offset IMG_20221108_072301893
Like I said earlier, you're fine. No way you'll rub.
R-E-L-A-X.
Dannybles
Danny
philadelphia
2020 civic hatch ex
I think you’re right
Just out of curiosity, what size wheels and tires did you go with?
Dannybles
Danny
philadelphia
2020 civic hatch ex
Wheels: https://www.tirerack.com/wheels/enkei-performance-edr9-black-painted
  • Size: 17x7(Factory Diameter)
  • Offset: +45mm
Tires: https://www.tirerack.com/tires/continental-extremecontact-dws-06-plus
  • Continental EXTREMECONTACT DWS 06 PLUS, SIZE: 215/50ZR17
    Also I just drove it about 12 miles on him in this city. Pretty nice a little little bit louder than I thought but not bad at all definitely satisfied with the purchase. I wish that they were lighter weight though. This combo is one and a half pounds heavier than stock. And I was trying to go lighter. However the wheels themselves are probably 3 pounds lighter than the stock wheels.
Ok, just 100% double checking. That's exactly the same as stock (diameter, offset, width). No issues at all and great choice of tire. They're amazing.
arpypat
Civic
The DWS06+ run a little wide. Still wouldn't be worried about rubbing with those wheel/tire specs.
I have the DWS06+ in 245/40r18 and they are wider than the 255/35r18 summer tires I had on a different set.
Dannybles
Danny
philadelphia
2020 civic hatch ex
Yeah only got 18 miles on them so far but I do like the tires however I did expect to lose at least 2 pounds on each wheel instead of gaining a pound and a half. Other than that everything‘s fine except maybe the tires are slightly louder than I expected.
