2017 Si w/ 28k miles. Emissions problem, Power Steering problem, Traction Control problem, Hill Assist problem, etc.
N_W_F
Nate
New England
2017 Civic Si
Hi everyone,
For the past three years I have owned a 2017 Si coupe that was purchased used with 1200 miles. This car has been daily driven approximately 60 miles back and forth to work 4 days a week, gone on multiple road trips, and has been an absolute pleasure to own. The only modification that has been done to this vehicle is an acuity stage 1 shift kit plus the cable bushings. Service has always been done on time by the same certified dealer. In the recent past, it fell victim to the A/C failure that many have experienced, and it was fixed at no cost.
Living in the north east, it has been driven through inclement weather and does not have a spot in the garage at home. Moving forward, no, this car has not been babied its entire time on the road, nor has it had the crap beaten out of it. Quite religiously I have done a 2nd to 3rd gear pull on the on-ramp both to and from work, and cruise on the highway at about 75-85mph. On back roads I have enjoyed some aggressive driving in sport mode, but never pushed it past the point where I or the car felt unsteady besides a little tire chirping. Throughout these fun times I've had with the car, I've accidentally bounced it off the rev limiter a couple times initiating the first stage of a fuel cutoff, missed enough shifts to count on two hands, but never thought I had done anything that could be catastrophically damaging.
Last Thursday after a day of rain, a portion of the highway that I travel on was recently paved and a stream of water was consistently forming across the road, which had my traction control lighting up like crazy! On that same drive home, I floored it in 2nd gear after a stoplight and it spun out the tires to redline. Last Friday night, on my way home from work, after trying as hard as I could to dodge it, I accidentally hit a possum with both left tires resulting in a decent thud both times doing about 35 mph. No problems in the moment, felt bad about it and moved on.
Come Saturday morning when starting up the vehicle, I was greeted with a list of problems such as: Emissions System Problem, Traction Control Problem, Stability Control Problem, Hill Assist Problem, Brake Hold Problem, Power Steering problem, and while it was still idling in the driveway I tried to put it into sport mode and the car would not let me. I have a Verizon Hum tracker on my vehicle that keeps track of my driving and provides diagnostic codes when a problem occurs. The only actual code that I received was p0304 for a cylinder 4 misfire. I did some research and saw that the warranty from Honda was extended to 6 years / unlimited miles, so I arranged to have it towed to the same dealer that has always worked on it to be fixed. Earlier today I got a call from the dealer asking if I had made any attempts to tune my vehicle, in which I responded no and asked about the p0304 code, which he had not even addressed. He said that it was throwing a p0219 code, but could not provide any further information. After doing some research myself, my heart sunk as the code states there was an over rev of the engine which could leave me responsible for any damages if it is true. Further investigating, from what I understand there are certain circumstances in which a p0219 code can be falsely triggered. I'm sure my Verizon hum does not provide nearly as much information as a certified Honda scanner would, but I am shocked that this problem is only coming to light now after years of ownership and consistent service. I understand how this looks, and I am ready to face criticism if necessary. On the Thursday night during the storm, my hum read my average speed for the trip as 1203mph with a top speed of 82mph, and on Friday night said my average speed was 153mph with a top speed of 83mph which is unusual as it normally provides quite accurate information, which leads me to believe something involving the cars computers are going haywire. Do you guys think there is any chance that some sort of electrical component has severely failed which is providing a long list of false readings? The car will be sitting at the dealership until further notice, hopefully some good news can be brought to light.
I want to say thanks to anyone who took the time to read this, and would appreciate any input both constructive or criticizing.
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
My money is on the collision with the marmot. I can't explain the other, seemingly unrelated error codes other than it's all part of The Matrix. I'd test and check the RADAR unit (that's located on the left side). Good luck. And keep us posted.
DRUSA
Dan
2019 Civic Type R
All of the ridiculous hooning aside here lol, i think you probably smashed the output shaft speed sensor on the trans hitting the possum. It's located on the radiator side of the trans, towards the bottom. If you smashed up your splash shield good you could have damaged this sensor internally, hense the Mach 2 cruising speeds.
P0219 is not a good code number. Check the number again, code doesn't exist in Honda book.
N_W_F
N_W_F
Nate
New England
2017 Civic Si
  • #4
I’m going to call the dealership tomorrow and relay your potential diagnosis. I have not seen the p0219 code in person or heard any further information regarding how bad of an over rev occurred (if it ever even happened). I will have to further investigate, because that is the code my dealers master tech informed me of over the phone and it has made me lose sleep ever since. On Monday I was told I would get a call Tuesday, and as of 1am on Thursday I have not heard anything back from them. My daily commute has been much more docile in a 2001 suburban... looking forward to a little more hooning in the future. I will keep you guys updated. Thanks so much for all the input you guys
N_W_F
N_W_F
Nate
New England
2017 Civic Si
  • #5
Update:
I have heard back from the dealer, the car has experienced an over rev based on what the ecu recorded. They aren’t certain when it happened or how bad the damage is inside the motor, but it revved out pretty good.. ~7500rpm. I have owned this car for over two years at this point and drive about 250 miles a week. With a mostly highway commute, a cruising speed of 50-80mph is quite common depending on the road and conditions. Near the end of March on a drive home one night, I had a deer enter my lane on the highway while I was doing about 85 in 6th gear. I immediately slammed the brakes and proceeded to shift from 6th-3rd-2nd. I am assuming this is when the over rev happened.
It could have been worse, and I honestly didn’t notice anything wrong with the car at all. It must be a tough motor to withstand trauma like that and get me to work with a smile on my face for months without asking for help! The dealership is going to do a partial disassembly to look for any prominent damage like a bent valve, or see if the timing is slightly off, and if they can’t find anything, they will check the sensors before reporting back to me. Maybe hitting the possum was the last straw and something came loose which brought this all to attention.
Regardless, I’m glad a plan is being put together for its repair. I feel like a moron, but it is what it is sometimes. I’m proud to own it and plan to keep it for years to come. If it does need engine work, I would potentially be interested in shop recommendations in the New England area. Thanks everyone.
shoegazer
Raleigh NC
Hmm...
I'm glad you have a plan. I'm still not sure what the (over 90 days old) over-rev has to do with all this, though.
After re-reading the original post; I'm still suspicious of the marmot impact but also the rain event. I'm wondering if something got wet, began to corrode, and then was pushed beyond the threshold by the impact. Then... after cooldown and drying out, beginning to malfunction the next day. I also see the logic of the Speed Sensor being damaged and (therefore) causing all those system errors based off of bad data.
I'm not officially disagreeing with Honda here. But do be careful authorizing tons of diagnostic/repair work based on a *possible* engine error.
*not a mechanic. just an ocd hypochondriac that likes to troubleshoot.
N_W_F
N_W_F
Nate
New England
2017 Civic Si
  • #7
Hmm...
I agree, and definitely not trying to break the bank anymore than I already have given my drivetrain warranty void (R.I.P.). It was coming to and end soon anyway, but I’m trying to stay in control of the situation as much as I can. The mechanic who has serviced my vehicle for the majority of the time on the road has been quite understanding from the chats we have had, and hopefully won’t leave my pockets empty without my authorization lol.
I will keep posting updates as they arrive.
