WayahWarrior
The Yakima BaseClip numbers are 186 and 187, can't remember which is front/back as I installed them myself a while back. Your front towers and clips should be seated as perfectly as your rear ones though. I was honestly amazed at how perfectly everything lines up once you've adjusted all of the fitment settings. The towers are adjustable in literally every direction, they even tilt to level the jetstream or corebars (pic). It sounds like yours weren't installed correctly and deserve another look by the installer.For those of you with the Yakima baseline towers, what base clips did you use for the front and rear. I had mine installed for me and rear pads looks like a perfect fit for the rear, but the front there's a gap and part of the pad i son the roof. The rear is on the outer roof/near door and the weather strip that's separates the roof. Can you post pictures of your front and rear tower and how they sit on the civic?
