2017 civic sport..can someone please help
Thehatch17
Josh
Nc
2017 civic sport
I have a 2017 civic sport hatch.i installed an aftermarket stereo.in the process a wire must’ve touched something because the gauge cluster instrument is out.all the lights work except the 3 main ones.the temp,the fuel and the speedometer.i tried replacing fuses but I don’t think that might be it.i don’t want to replace the bulbs behind the cluster yet..I’m going to do that after ive tried everything else..any help is appreciated thanks.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
Just FYI, you're in the Type R "Engine|Exhaust|Drivetrain|Bolton" section. But your bulbs might be the least of your worries. If you fucked up the wiring there is a chance you blew an entire line or even damaged the actual electronics on the car which will be a very pricy mistake.
ManfromRI
RI
17' CW Civic Type R
Not to be a dick but..... First rule of installing anything electrical in your car, you should always disconnect the ground from the battery.
I would go thru all the fuses, fusable links, relays (under dash/hood) to see if anything is blown and go from there.
jayy_swish
Jay
It’s a fuse NOTHING in that car runs straight power from the battery without a fuse. That’s the point of a fuse, in the event of a short circuit or power surge they’re meant to blow to protect the electric components. Double check all fuses. And as stated above^^ ALWAYS disconnect the battery when working with anything electrical on the car, it prevents messes like this. Look through the manual for all fuse locations
