2017 Civic Si Ktuner Starter Maps (Only hp and torque available thr 23 psi map)
Bp216
Brandon
Houston
2020 Civic Si
I've been looking all over and maybe it is somewhere. When looking at the Ktuner site (https://ktuner.com/17civicsi), there is only a dyno chart or hp and torque numbers for the 23 psi map. Can anyone show me where I can find the numbers for the 21.5 psi map and even the other ones (19.5) or what they are?
When tuners publish dyno results on their tunes, they often only dyno the high output map.
Why would you need dyno numbers on the reduced power maps anyway? All three are safe and a big improvement over stock.
If you're concerned that 23 psi is too much, run 21.5 psi.
Bp216
Brandon
Houston
2020 Civic Si
Thanks for the response! Yeah I only plan to go 21.5 but was just curious on the approximate increase over stock. Is this something someone have published?
Bp216
Brandon
Houston
2020 Civic Si
Also I was concerned with the highest output map since so many people have mentioned clutch not handling the torque. I wouldn't want to be thinking about controlling the car in a way to work around knowing the clutch might slip if I get too aggressive.
AdamSI
Adam
rohnert park
2018 civic si coupe
the 23 ktuner can be pretty aggressive if you max all settings out. boost ramp rate,early spool,throttle response, turbo responsiveness. don't WOT in 5th and 6th gear
repeet
Fort Mill, S.C.
jesus7feasts.fyi
'23 BRZ
Lots of good advice, but the original question hasn't been answered. Does anybody have a dyno of the 19.5 and 21.5 maps?
