ztsmith
- Zack
- Sep 6, 2017
- 5
- 2
- CT
- 17 Civic Hatchback EX PMM
- Vehicle Showcase
Hey all started recently having some AC issues with it running intermittently hot and cold at times. Recently it started to make a noise that sounded like running water throughout the air vents only while the AC is on. Brought it in outside of 3 yr 36k warranty (at 35k miles, almost 1 yr out of warranty) to have the system checked. Paid for diag, found out the condenser was ok but the AC drain was draining properly, causing it to hold water (he said about 1-2 gallons), which caused the "running water" issue. Cleared out the drain. 1 problem down.
Found out that refrigerant was low. They recharged the system back up and added dye. Through testing they determined there was a small crack in the AC Compressor to the tune of $1600 roughly. Said it was not a pressing issue and may be able to make it through the summer. I just made a call into Honda USA to open up a goodwill case.
Has this happened to anyone else?
