Dan O Mite
- Dan
- Aug 1, 2022
- 2
- 3
- 0
- Grande prairie alberta
- 2017 civic lx sedan
Long story short
Engine light and bunch of warning lites
Cleared Them All. I Disconnect battery.
Engine light warning back with short drive.
Borrowed Code Reader (Autel) got p0341. Cleared codes.
Got couple sensors from Honda Switched them out did all resets and learns (confirmed on scan tool Live data).
Still getting code.
Changed out original battery to New (good not cheap).
Still p0341 comes up.
Scanner says my VTC Oil Control solenoid valve is working when code has been cleared and is Off when code is active. Scan tool also shows a bit of difference between VTC Advance angle and Target Angle. If I drive Granny style No codes Give Her Gas (half pedal) Code returns.
So New Sensors, New Battery, working Soenoid valve.
Timing Chain? No Rattle on Cold Start.
Leaves VTC Actuators or Auto -Tensioner.
Getting too it (long story Thanks For Hangin in)
Need to Open Her Up to find out. Tensioner will be out of spec when measured or Actuator will be in UnLocked position.
Now No parts in stocks Need to order in from out of town 3-4 days away except for Actuator Part # 14320-5BA-A01 None in stocks maybe end of October ( which is the more expensive leading me to say Intake side B Sprocket).
Now The Question
What should I do Next?
Any Advice or Questions
Still getting code.
Now The Question
