leehom
- Jun 17, 2017
- 4
- 232
- 128
- under your bed
- Honda, back at it again
I'm not sure why so many people are skeptical about Honda updating the CTR with the 2019 MMC Civic. The ITR was released in 97 when the Integra DC2 was initially released in 1994. In 98 Honda updated the Integra and the ITR with it. That's one model year the ITR was released before it got an MMC.
I'll happily eat crow if I'm wrong, but it logistically makes zero sense to keep the CTR different from the rest of the line up. Some people want to dismiss the MMC upgrades as very minor should look at the S2000 changes from MMC. The CTR might not get as many updates as the S2000 did, but we will get some noticeable ones.
Second generation (known as "AP2" and in Europe as "AP1 facelift" - 2004–2009)
The 2004 model S2000 underwent several significant changes. Production moved to Suzuka. The new model introduced 17 in (43 cm) wheels and Bridgestone RE-050 tires along with a retuned suspension to reduce oversteer. The spring rates and shock absorber damping were altered and the suspension geometry modified to improve stability by reducing toe-in changes under cornering loads. The subframe also received a revision in design to achieve a high rigidity. In the gearbox the brass synchronizers were replaced with carbon fiber. In addition, cosmetic changes were made to the exterior with new front and rear bumpers, revised headlight assemblies, new LED tail-lights, and oval-tipped exhausts. Although all the cosmetic, suspension and most drivetrain upgrades were included on the Japanese, Australian and European S2000s, they retained the 2.0l F20C engines and remained designated as AP1s.
2005 Honda S2000
For the North American market the updates also included the introduction of a larger version of the F20C (F22C1), this larger engine gave the chassis designation AP2. F22C1, the engine's stroke was lengthened, increasing its displacement to 2,157 cc (132 cu in). At the same time, the redline and fuel cutoff were reduced from 8,800 rpm and 9,000 rpm to 8,000 rpm and 8,200 rpm respectively, mandated by the longer travel of the pistons. Peak torque increased 6% to 220 Nâ‹…m (160 lbfâ‹…ft) at 6,800 rpm while power output remained unchanged, 177 kW (237 hp) at a lower 7,800 rpm. In conjunction with its introduction of the F22C1, Honda also changed the transmission gear ratios by shortening the first five gears and lengthening the sixth.[10]
