Brandons2697
So there's two brown and two yellow wires on the RR Speaker. Are both of the yellow positive and both of the brown negative?
When someone has a chance, can someone answer my question about this? It would be very helpful. Thank you.So do you have to have the adapter for the controls on the steering wheel if you have the metro wiring harness 70 1731 for it to work? I don't want to buy another adapter if I don't have to
Sorry, didn't even see it. Yes, there is a separate harness for the steering wheel controls. I can't remember the number though.When someone has a chance, can someone answer my question about this? It would be very helpful. Thank you.
The harness that I purchased from quality mobile video had the steering wheel control harness prewired. You still have to buy the aswc-1Sorry, didn't even see it. Yes, there is a separate harness for the steering wheel controls. I can't remember the number though.
Oh, I wouldn't be watching it, but it would help keep my son occupied on the 1 hour drive to his Grandpa's house.Yes it can if you wire it correctly, however it likely would not be safe
That's it, that's what I was trying to think of. Thanks.The harness that I purchased from quality mobile video had the steering wheel control harness prewired. You still have to buy the aswc-1
Yes, the phone control buttons work as well. Remember, though if you want to use the factory microphone like me, remember to wire the extra pins like I didCan you still use the feature where you hit the button on the steering wheel and say a name to make a call?
I am going to have it installed by a professional at Custom Sounds here in Missouri. I have taken my car up there to get the windows done and they did a great job in the past.
I have the Pioneer 41000 NEX, Metra 95-7812B Faceplate, AXXESS ASWC-1, Metra 70-1731 Harness, Metra 40-HD11 Antenna Adapter.
It will be installed on 7/21/2016. Wish Me and the installers luck!
Well the professionals did a good job getting the radio working correctly including the controls for the up, down, left right and source. The only problem I had trouble with is that the dash kit has to be modified in order to take the face off and put it back on correctly. So the guy at custom sounds is working on doing that for me since I ordered a 2nd dash kit on accident anyways.I am going to have it installed by a professional at Custom Sounds here in Missouri. I have taken my car up there to get the windows done and they did a great job in the past.
Modifying the dash kit for the Pioneer radios is super common. It has to do with how the motorized screen opens. It first goes up then out and the little slide (button? switch?) you have to move to take out the faceplate almost always gets caught on dashes. Also the radio looks like its sitting back in the kit in your picture. I havent done a radio yet in the new civics so I can say how easy it is to modify the kit (I think it should be simple, just a little dremel work around the inside edges) at least thats how it has been on any of the kits with pioneer radios Ive done so far.Well the professionals did a good job getting the radio working correctly including the controls for the up, down, left right and source. The only problem I had trouble with is that the dash kit has to be modified in order to take the face off and put it back on correctly. So the guy at custom sounds is working on doing that for me since I ordered a 2nd dash kit on accident anyways.
Other than that they had to flash the steering wheel controller a few times to get it to start working correctly. Everything works well including Apple car play!
Love it!!!
