2016 Civic Coupe EX-L /Modern Steel Metallic
TedBCivicX
Elizabeth, PA
2016 Honda Civic Coupe EX-L
does it feel more sturdy the way you have it bolted? when i read the offically instructions for the oem spoiler they use brackets to support the spoiler, im just wondering if these small screws will be enough to hold the spoiler in place
Yeah but I didn't know about the brackets either. I know the real stock one also comes with a new spring system, that rod you need a special tool to install, but my trunk opens and stays open fine.
handa
2016 Honda Civic Coupe 2.0 (Traded), 2017 Honda Civic Hatch LX 6 Speed (Current)
did you just go to home depot and pick up the longer screws? hm i was curious if it still opened using the remote? sorry for so many questions this is my first time doing this so any advice is appreciated
TedBCivicX
Elizabeth, PA
I went to a.local hardware store but Lowes or home depot would be fine. It doesn't open all the way when u push the button anymore, just about an inch or so. I wasn't to concerned.
handa
damn that installation was a fucking nightmare lol
TedBCivicX
Elizabeth, PA
different looking, but I think with the way the mounting holes are drilled for the current one (kind of a triangle on each side) I don't think you could use this without a hole showing on each side unless you plugged them.
handa
yeah i know talk about instant regret
turbodaily
NC
'16 Civic Coupe
I ended up changing the tips to something more subtle that wasn't as close to the bumper..
Came across your car in the forums, I like it. I almost have the same car, except I just have a T instead of an L for the model. Do you remember what exhaust tips you got and where you got them from? I like how those are pretty subtle like you mentioned.
TedBCivicX
Elizabeth, PA
Auto Zone, $12.99 each... They have a mesh layer inside them. I trimmed the back part at the bottom to allow the tip to be more angled - the top of the tip is just barely visible. You have to trim.the stock exhaust exit as well.
turbodaily
NC
'16 Civic Coupe
Gotcha, thanks. I might look into a solution like that then.
TedBCivicX
Elizabeth, PA
and Thailand RS black grill... Pain in the a but looks fantastic... No more painting or touching up my grill.
TedBCivicX
Elizabeth, PA
I replaced some of the bulbs with LEDs:
Low Beam:
http://www.ebay.com/itm/122135145626?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Fog Lights: (had to trim the tabs on the LEDs to get to fit, but not a huge deal)
http://www.ebay.com/itm/282149919817?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Brake Lights: (didn't touch the 3rd brake light though)
http://www.ebay.com/itm/252484760245?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
and the Backup lights: (These are way more intense than I thought they would be, helps the backup camera at night a LOT)
http://www.ebay.com/itm/201258049619?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
