Oddwayne
- Mar 3, 2019
- 6
- 582
- 249
- Nj
- 19’ Si coupe & 99 ej6
If you have a leak or removed a hose without bleeding the system, you have air pockets. If the system is fine and never been messed with, highly unlikely you have air pockets. Most dealers tbh are just going to drain the rad and fill back up. Some don’t wanna deal with draining the block or have the kind of equipment that adds and takes away coolant while the motor is running. If it were me and depending on how cheap I got the type 2 coolant for, I may do a drain and fill of the rad, bleed, drive around for a day or so and do a second drain and fill.I already bought the Honda coolant. Just need to figure out if I can flush it or just drain from lower radiator and refill. How likely are air pockets in the coolant circuit?
