David Harper
- Apr 28, 2016
- 64
- 884
- 420
- Crystal Lake, Il.
- 2016 Civic coupe
https://www.cenex.com/about/cenex-i.../what-octane-ratings-really-mean-for-your-car
"An octane rating is simply a measure of how heat resistant a fuel is in order to prevent knocking. In other words, octane doesn’t enhance combustion — it prevents the air-fuel mixture inside an engine from igniting before it’s supposed to.
The higher a fuel’s octane, the more resistant it is to knocking. If you hear knocking, you could be using the wrong octane for your ride. The recommended octane rating varies by vehicle, so always consult your owner’s manual to determine which is right for you. Some vehicles require a higher octane rating because they have what’s known as supercharged or turbocharged engines that create higher compression levels."
https://www.eia.gov/energyexplained/gasoline/octane-in-depth.php
"Octane ratings are measures of fuel stability. These ratings are based on the pressure at which a fuel will spontaneously combust (auto-ignite) in a testing engine"
A simple google search would tell you what the differences actually are instead of what you just "believe" to be true (I believe that the way premium allows for higher potential maximum cylinder pressure is by delaying ,in effect, combustion")
[/QUOTE]
If octane makes the fuel more "heat resistant" as you stated, then that IS, IN FACT, delaying combustion. Are you not intelligent enough to get this?
