Glowzzy
- Nov 12, 2019
- 24
- 6
- North Carolina
- 2019 Honda Odyssey, 2016 Yamaha XSR900, Soon: Civic Type-R
- #31
Awesome!!!! I want a limited edition as well since the Phoenix yellow is awesome looking, my local dealership is getting one this quarter and that is the one I'm waiting on. They have several customers on it though, so if I don't get it, then I plan to get a white one and wrap in Inozetek Dandelion Yellow, which is not the same as the limited edition Phoenix yellow, yours actually looks closer to factory. Looks great!Attached is is the dimensional inspection for the front brake. I am a mechanical engineer that specializes in turbomachinery and have dimensionally inspected hundreds of machines. Not all the dimensions in the spreadsheet are precise to the .001" Some of the dimensions are impossible to precisely get such as M,B,C,D. The best way to get the D dimension is to measure the distance between the caliper and the ID of the wheel, then measure the ID of the wheel and calculate the D dimension, which is what I did. That dimension is not precise to the .001" due to the tools and method of measuring. The D dimension could be off by 1/8"- 1/4". All the axial dimensions are precise as well as the hub dimensions. If I was specifying wheels with the numbers I took, I would make absolutely sure the new wheel inside diameter would allow for the uncertainty in the D dimension.
I am wrapping the car in a yellow that is close to the Phoenix Yellow of the limited. I also tinted the head lights.
Thank you for the measurements, they should be good enough, I will send them in and let you know what I find! Thank you.
