18x9.5+45 with 265/35 tires on a sport hatch?
Ap1 George
George
Las Vegas, Nevada
2017 SGP Civic Sport Hatch 6MT
I tried digging around for this specific question and I seen these specs done on a civic si sedan and looked great. I guess my question would be is do all Civic X share the same wheel/fender clearances with the exception of the Type R? Thank you for your time.
Here is my Sport Hatch in 6MT
Honda Civic 10th gen 18x9.5+45 with 265/35 tires on a sport hatch? civic
Hoang_Honda
Hoang
Orange Country CA
15 Accord V6 Touring. 17 Civic Si Coupe.
Type R is wider and have no rubbing issues with 9.5 and 265 tires but I don't think this spec will fit on non type r civic. U might try 245 tires but that looks so stretch.
swah_fk7
Regamaster King
Martin
Miami, FL
245 on a 9.5 is not stretch... lol They bead on the tire with 0 issues, just inflate.
265 and 35 might be pushing it, i know for a fact you'll be able to run a 255 35 18 no issues. BMSpec runs a 295 30 18 on their car and that doesn't rub (Time attack build)
Ap1 George
Ap1 George
George
Las Vegas, Nevada
We already know the Type R has more wheel and fender clearance hence I made an exception for it when I mentioned all Civic X. My question was if ALL Civic X share the same fender/wheel clearance WITH the exception of the Type R. I ask because a member here had done the same specs with his being 5mm more aggressive in offset than my thread title.
Honda Civic 10th gen 18x9.5+45 with 265/35 tires on a sport hatch? upload_2019-8-9_14-46-43
Ap1 George
Ap1 George
George
Las Vegas, Nevada
245/40 on a 9.5 is indeed a stretch. Even the stock 235/40 on an 8 is a stretch. There's close to 25mm to an inch if we add 1.5 inches from 8 inch width wheel while adding only 10mm from the 235/40 which is less than half an inch will stretch. Any sidewall that is diagonal outwards is a stretch.
Ap1 George
Ap1 George
George
Las Vegas, Nevada
18x9.5 +40 265/35/18
Lowered on eibach pro kit.
No rubbing whatsoever.
That looks great! that's what I'm going for! is this an Si sedan?
Hoang_Honda
Hoang
Orange Country CA
Rear no rubbing because it has more clearance but not front. Go and look at your liner tab where it has a screw and close to the side maker unless u have camber @Manfully
Manfully
Honda CR-V
Yes indeed si sedan
You sure about that? You haven't ridden in my car. 2019 si sedan doesn't have the tab by the corner light any more. No rubbing.
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Hoang_Honda
Hoang
Orange Country CA
@Manfully I didn't know Honda remove that liner tap for 2019 Si but don't u think OP sport hatch is different? I have to go out to check my bro's CTR his is 2019 model and the liner tab is still there hmmm
Honda Civic 10th gen 18x9.5+45 with 265/35 tires on a sport hatch? 20190809_191413
Ap1 George
Ap1 George
George
Las Vegas, Nevada
265 35 hankook on 18x10+39. Rubs fender liner by front corner light on hard bumps or dips. No tab to mod . Lowered on d2.
Thanks! If it only rubs on hard bumps and dip then 18x9.5 +45 with 265/35 with totally work since 18x10+39 is much more aggressive in comparison! Thanks so much
Ap1 George
Ap1 George
George
Las Vegas, Nevada
I was gonna check it out until I found my answer on Instagram LMAO.. I saw a sport hatch rocking a 18x9.5 +35 with the same tires with his wheels being 10mm more aggressive in offset and had no problems whatsoever even being moderately lowered
