18x9.5 +35 (What tire?) Aggressive
BigBrothaAgil
Norfolk, VA
2017 Civic SI
I'm set on the wheel size which is stated above sitting on skunk2 springs for now. I am looking for a more aggressive look. I noticed these are the most popular
245/40
255/40
255/35
or 265/35.
I want to know which tires people use and the changes they made when using that tire with this wheel size. Any help is appreciated.
Masked
Jos
Quebec, Canada
'18 Civic Si Coupe
I have 18x9.5 +38 on mine with 255/35 Firehawk Indy 500's, no rubbing and perfect fitment. I'm on stock suspension though so you might have a slight rub with skunk2 springs, someone else will need to chime in. I wouldn't do 255/40 so either 245/40 or 255/35 will work in most cases with that wheel size
Edit : 245 if you want slightly more stretch
BigBrothaAgil
Norfolk, VA
2017 Civic SI
Mind if i see a picture
Bail
Matthew
2019 Civic si
Check out the Aggressive Wheel and Tires thread in the wheels and tires section. There's literally hundreds of setups.
