too
'16 Civic LX, 6MT. I just got my tires replaced and everything worked fine before the service.
When you pull up the parking brake switch (engine on), the parking brake won't engage; red "BRAKE" light would flash; the yellow "BRAKE SYSTEM" light would be on solid.
If you shut the engine off, a few seconds later, you can hear the parking brake engage. I checked - both rear brakes engaged, not just one. When you turn the engine on, the red "BRAKE" light stays on (normal, just as when parking brake works normally). You can disengage and all seems normal. But if you try to engage the P-brake again, the symptom repeats.
Some more info:
- Brake Hold function works as normal
- Checked the brake fluid, it's full to the Max line
- Checked the rear brake units and the wires to the brake calipers - all seems normal
- Disconnected the battery and reconnect - did not fix the problem
- Inspect the calipers, no leaks
- Brake system bled 2 months ago
- Checked the brake fluid sensor at the reservoir (under the hood), connection seems fine and solid - no obvious wire breaks
- Ran OBD II diagnostics, no error code
- Battery voltage is 13V, engine off - good here.
I'm out of ideas. Any suggestions?
Some more info:
