'16 Civic, Rear Rotors Scorched, Cracked & Rusted
Ziyang
Ziyang
New Haven CT
2017 Civic ET-T MT
Hello,
Same here for 2017 Sedan EX-T. I live in CT with salt roads in winter. Same worn-out rear rotors after 52k mainly hwy mileage. In fact they make some noise after rain and cold-start now...
I'm looking for replacement from tirerack, but not sure if these will fit with the stock caliper.
Comment on aftermarket rear rotor/pad set
Ziyang
Ziyang
New Haven CT
2017 Civic ET-T MT
Well this sucks. Amazon Prime is telling me like 3 weeks until they can deliver that brake tool..
I wouldn't recommend that tool; it's not used in official SOP, and some people had EPB errors after using it. I'd recommend you go with the actuator method. Just get TORX E socket and T bite.
Gear kit for service You are also supposed to replace the O-ring after remove the actuator.
civicmanic
2016 Civic Touring ; 2020 CR-V Sport(wife)
Who had errors using it? Just wondering because myself, and every video tutorial I've seen used the wind back tool(with e brake off) and none of us had any problems. I realize this is not "by the book", but I can say first hand it works.
And the centric pad a rotor set you linked to above is the correct parts. Cheaper to get from rockauto. It's the same parts I used.
Ziyang
Ziyang
New Haven CT
2017 Civic ET-T MT
I can't remember...there are people posting the EPB error after setting it back with the winding tool in the forum...
Thanks for confirmation. I'll buy it soon 🙌
civicmanic
Maybe I am not searching deep enough, but I can't find these people who are having issues. I found paranoid people talk theoretically about there being issues. I tend not to be a paranoid person. In practice, I found numerous people here on the forums and in videos do it the way I did it and had no issues.
jackson
CDN
2016 Civic LX
  • #36
So to report back. I finally got the tool as per the Amazon link last weekend, finally had time today to do the brakes.
The instructions are somewhat unclear, is one supposed to remove the actuator, wind the Etorx thing back clockwise until its locked. Proceed with brake pad/rotor remove. Then once new pads are installed use the wind back tool to turn the caliper cylinder/piston back in order to slide caliper back over the new pads?
I am not sure is that universal brake caliper tool supposed to be in lieu of having to remove the actuator or its needed in addition to?
In either case, I did as I just asked about today. Turned the car to ON, activated the parking brake, let the parking brake off. Turned car off.
Restarted car and went for a drive all is fine.
abitolder
ontario
17 accord
It could be that you are not servicing your caliper slider pins/bolts, caliper could be sticking at times ( not always) and overheating. Also if car sits for a day or two in winter with parking brake on it will start to leave little corrosion marks on the rotor that will get worse, I do tend to spray wash the area around the callipers in winter every few days at the car wash when weather is snow/slush. Just an idea.
coo1rim
toronto
1998 civic, 2006 yaris, 2008 rav4, 2012 carmy, 2017 Civic 2.0L 6MT
Over 70k miles on my 2017 Civic. Never service the brakes. Rotors still looks good and pads are at 30%. Also, I live in the salt belt. My car never sits, so probably why brakes haven't ceased or rusted out.
Spacesloth
Wisconsin
2017 Honda Civic SI
Did you happen to have your car rust proofed somewhere like Ziebart? I notice a thick coating of something over suspension components.
