10th Gen Civic Light Bulb Size Guide
Status
Not open for further replies.
a c i d.f l y
Austin
2017 Honda Civic EX 2.0 CVT Sedan w Sensing
My vote for a sticky thread, but should probably be moved/copied to the exterior forum.
Thanks for posting this, btw.
TypeRLEDs
TypeRLEDs
#1 Source for 10thgen LEDs
Houston TX
TypeRLEDs.com
2017 Honda Civic Type R
My vote for a sticky thread, but should probably be moved to the exterior forum.
Thanks! Glad the guide is useful.
Updated. Indicated Front and Rear Turn signals.
a c i d.f l y
Austin
Is there any way to replace the subtle light in the storage area under the head unit without ripping things apart? Would like to replace that with a green instead of the blue...
chestypuller
Skip
alaska
None
depending on what bulb it is, they make silicon colored covers to tint them check into that maybe easy
M1KL83
Michael
Ontario, Canada
2018 Civic Hatchback LX 6MT, 2002 Honda Accord SE 5MT
Parts Source says the factory side marker bulbs are 2821's and at 3 amps..
194's are 3.8 amps.
What is right?
Kirinya
Texas
2018 Civic Hatchback EX
I thought it was a dim white light to start with?
I would also like to know this, want to replace with a brighter light to see the storage area.
bri
OC, CA
2018 Civic Type R, 2010 G37S
I believe the reverse backup lights in sedan are 921, same as nearly every other car. I just replaced mine with LED.
TypeRLEDs
TypeRLEDs
Houston TX
TypeRLEDs.com
Yes. Correct. Same as T10.
bri
OC, CA
The socket is the same, but in incandescent 921 are higher wattage and burn brighter. Accordingly, 921 labeled LEDs typically are much brighter (even though the wattage is in a different range than incandescent) using larger number of higher output LED chips than T10/194 labeled LEDs. T10/194 labeled LEDs are going to be really dim in a reverse socket.
danny185
Danny
Puerto Rico
Honda Civic SI 2017 Sedan
Hey guys I got the brake light on led but what are the ones that illuminate the whole red light on the tail lights? What bulb size?
Accordlayingkit
Virginia
2017 Honda Civic Hatchback EX
Anyone got a link to order the visor bulbs that have been confirmed to fit and work? (T5 bulbs)
Thanks!
Edit: you guys think these will work in the visors?
iJDMTOY 4pcs Extremely Bright 9-SMD 29mm 6614 LED Replacement Bulbs For Car SUV Truck Sunvisor Flips Vanity Mirror Lights, Xenon White https://www.amazon.com/dp/B018J69J6W/ref=cm_sw_r_other_apa_.Y-wBb95E38B4
Or these
LEDpartsNow 5mm LED Light Bulbs for Vanity Mirror Sun Visors, T5, 70, 74 Basic Miniature Bulb (2 Pieces), WHITE https://www.amazon.com/dp/B075L3XPGG/ref=cm_sw_r_other_apa_t0-wBb1F8AB34
I'm guessing it would be the 2nd ones since those visor bulbs are wedge style
Honda Civic 10th gen 10th Gen Civic Light Bulb Size Guide 20180728_092335
Accordlayingkit
Virginia
I forgot to get rear amber LEDs for my turn signals so I plan to order. I'm guessing this below is to cure any hyper flash?
*Note if installing LED turn signals for front and back; you'll require a load resistor for either both or one.
Anyways ...what are load resistors and where do I get them from?
Thanks!
Edit: figured it out lol
https://www.civicx.com/threads/turn-signal-led-bulbs.4977/
Status
