1.5 Turbo Motor Build
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
We figured that it's only a matter of time before somebody pushes the 1.5T platform to the max and know that we will eventually need an engine with forged internals. We decided to follow suit with the rest of the platforms we're involved in and develop a motor program for the 1.5 Turbo.
We will be using brand new OEM Honda Si cylinder blocks, crankshafts oil jets/squirters, gaskets and hardware.
2017+ Civic Si block
Notice the coolant passages at the tops of where the sleeves intersect. Also notice the aluminum cast around the top layer of the iron sleeve.
Main caps; no main girdle here. Honda's past K-Series motors featured a factory girdle system.
Awe look how cute! 73mm Si 10.3:1 compression piston.
The factory piston features a narrow piston skirt with a unique "spotted" friction coating.
These pistons also have quite a bit of material between the rings; A rather beafy design.
Such a cute little factory connecting rod!
M6 rod bolts :(
The rotating assembly can ALMOST fit an a USPS Large Flat Rate Box! :lol:
The left side is a 2.0L Type-R connecting rod, right is a 1.5T Si connecting rod.
The left side is a 2.0L Type-R piston, right is a 1.5T Si piston.
Our goal is to offer a short block capable of holding ~500 whp. The build will most-likely consist of forged H-beam rods and forged pistons. We will be working to develop a drop-in piston set designed to mimic Honda's factory piston design. This will be extremely important for fuel atomization and combustion with the direct injection system. A ~10.3:1 compression ratio is a rather comfortable number for us as well, as it's high enough to keep turbo spool and response there, but not high enough that we are worried about detonation/knock issues.
We are also sourcing/developing a proper head stud and other components to be able to hold the power as well. Please stay tuned! :thumbsup:
omigulay
Vancouver, Canada
2017 Civic Sport hatchback
I just saw it on your instagram account. Very exciting news!
Is the block different between the SI and regular 1.5T?
05NBPDC5
Jacob
Alpharetta, GA
05 RSX SC, 2011 RDX, 92 Civic hatch
Also, I believe the left and right are reversed from your description.
cmwalton16
Tennessee
2017 Civic Si Coupe ABM, 2016 Civic Touring CBP
M6 rod bolts :(
The right side is a 2.0L Type-R connecting rod, left is a 1.5T Si connecting rod.
The right side is a 2.0L Type-R piston, left is a 1.5T Si piston.
First a clutch and now this... OKAY take my money SI!!! :love::love:
maaaaackle
Socal
Sport Hatch 6MT
Wait.
PRL, I think your left/ride side is switched. You're tellin me that the Type R connecting rod is THINNER than an SI?
WHAAAAT?
jk. i know.
supaslow10g
Hattiesburg ms
2016 civic lx 6mt 05 Chevy Avalanche 2wd 2000 3G eclipse gt
should have bought a better trim......lol
and get the cvt you can't do much with and honda sensing I'll never use for 15 grand more. or pay the outrageous jacked up dealer prices I can't afford for a type r. a proper turbo kit for the lx and it'd basically be a type r under the hood plus some with a little beefier setup. and still be in it for less than 30k. I just hope someone shows some to the na 2.0 eventually. if not guess I'll have to stepup to a si now that they are putting out such serious upgrades for them.
  • Like
Reactions: 18k
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
  • #12
The part numbers are different, but there isn't much information out there about any differences. The Si block has been rumored to be stronger, but we cannot confirm this yet. From a monetary standpoint, though, the Si block is actually cheaper than the base 1.5T block!
Wait.
WHAAAAT?
jk. i know.
Apparently I don't know right from left! :doh: Oops haha
stop messing with these tiny toys and build a turbo kit for those of us that bought the lx for 2.0 and stick pls lol
That is a possiblity... We will see! ;)
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2012 Acura TL California Edition / 2018 Civic Si Coupe /2020 Civic Type-R
You can still see the image but you have to click on the photobucket link... they changed their policy and reduced the storage size now to 2gb anything over that and you have to pay $$$$$:thumbsdown::doh:
