1.5 T CVT, radical performance improvement with 30% toluene?
aydingokce
Turkey
2017 Honda Civic HB 1.5 Sport CVT
Hello everybody,
The title speaks for itself, but let me explain the situation. Last weekend, I went to a local tuning shop to buy some ethanol to upgrade my fuel. They told me that they did not have any ethanol but they did have toluene and if I use at 30%, it will work very well. THey told that hey preferred toluene over ethanol. To be honest, I did not believe this but I still purchased it, given the fact that it was affordable and I thought that trying once would not give any harm. So I calculated the necessary amount of toluene to create a 30% toluene fuel (roughly half of of the fuel on board) and tried the car. The result was really shocking: The car could keep up with 2013 Peugeot 208 GTI (1.6 THP 200 HP) and 2013 Polo GTI DSG (1.4 TSI Twincharger 180 HP). Normally, there is a considerable difference in performance with these cars because Civic is quite heavier and CVT effectively kills the power.
I was surprised to get such a significant result. Indeed I live in a country where tuners always complain about the low gasoline quality, but, still, I was not expecting so much. Seeing such an improvement made me consider the potential harms of adding toluene into the fuel and this is the main purpose of creating this thread. Do you think (or know) that this is harmful for the car?
CivicChina
Xiamen, China
Civic 1.5t 6MT Cosmic Blue
the manual civic can keep up with these cars. Isn't it easier and safer to change gears than buying, calculating, mixing dangerous unknown liquids in your tank?
aydingokce
Turkey
Manual version is not sold in my country, only CVT is. In october Type R will be on sale but it will be prohibitively expensive due to the extremely heavy taxes applied to the cars with displacement more than 1600 cc.
aydingokce
Turkey
I see. The problem with ethanol is, it is harder to find. Some legal procedures are required to get it, since it may be used for illegal alcohol drink production.
CivicChina
Xiamen, China
i would be careful because our engine has a very high pressure direct injection system, with high precision pump and injectors, calibrated on pump fuel, there are also plastic and rubber parts not tested for other solvents. I would not take this risk on a new car.
If you want more performance without extreme risks i suggest a tune from hondata or ktuner.
fiend busa
2018 Civic Type R
Vit himself runs E85
Civics4Ever
Rally Red EXT
Gene
Illinois
Car and Driver got a 0-60 6.6 seconds with the CVT. You also probably haven't read that on a Dyno, the Civic 1.5T has actually 192 HP, not the 174 that Honda rates it at. I went heads up with an Acura RDX and we were dead even. RDX has 270HP or so. But it's also 6-700 pounds heavier.
weigle2
Chicago
2016 Civic EX-L
Toluene is a common octane booster used in the US, and many other countries. Just Google it, and you'll see it's not unusual to be used in gasoline.
