VividRacing
- Austin
- Nov 28, 2018
- 154
- 471
- 130
- Gilbert Arizona
- FK8
Vivid Racing Presents:
PROJECT MU SCR-PRO 2-PIECE FRONT ROTORS | 2017+ HONDA CIVIC TYPE R
[email protected] | +1.480.966.3040 x254 | www.vividracing.com[/b]
Product Information:
Contact Me Directly for Forum Exclusive Pricing!
Can Include Project Mu Pads for an additional cost!
Project Mu is proud to announce their OEM-Brembo-compatible 2017+ Civic Type R 2-piece front rotors. These rotors have the same 350mm diameter as the OEM counterparts but feature a thicker (35mm), slotted, and vented design.
The "floating" rotor is made from a special PMU FC Cast Iron and Carbon Alloy which is an improvement over OEM and other Cast Iron alloy rotors. It features 10 slots per side and has large 48x20mm inner vents arranged in a radial exit path to improve airflow and heat dissipation. These modular rotor disks are pre-bedded and ready for use!
In order to combat the added weight of the thicker rotor, PMU decided to go the 2-piece route using a forged black aluminum bell housing. The aluminum is dual purpose in unsprung weight reduction and heat dissipation.
Applications:
- Honda Civic Type R [FK8] (2017, 2018, 2019, 2020) - made for OEM calipers
FEATURES:
Compatible with the OEM Brembo Caliper
Sold in pair for the front
2-piece design for added thickness at a lower weight
Special PMU FC Cast Iron and Carbon Alloy disks
Heat treated for added strength and durability
10 slots per side + radial vents
Forged aluminum center bell top hats
Made in the Japan
EXTENDED INFORMATION:
Type: Brake Rotors
Side: Left and Right (Sold in pairs)
Disk: Sold separately (for replacement)
Disk Diameter: 350 [mm]
Disk Thickness: 35 [mm] (OEM is 33mm)
Slots: 10 per side
Disk Vents: Radial
Disk material: High-alloy high-carbon FC cast iron coated with rust-resistant agent
Bell Housing: Ultra-hard aluminum alloy and alumite coating
Disk Finish: Heat Treated + Pre-Bedded
Pin Attachment: 10 high strength alloy steel bolts
Chassis: FK8
