VividRacing
- Austin
- Nov 28, 2018
- 154
- 471
- 130
- Gilbert Arizona
- FK8
Vivid Racing Presents:
KTUNER ECU Flash with Touchscreen Device V2 Honda Civic Type-R 2017+
Contact Me Directly for Forum Exclusive Pricing!
[email protected] | +1.480.966.3040 x254 | www.vividracing.com[/b]
Product Information:
SPECIAL PRICING FOR A LIMITED TIME
What tunes will be included?
- The stage 0 tune adding 20whp and 35wtq.
- The stage 1 tune adding 50whp, more in the low-midrange, and 65wtq.
- The stage 1 dampened low end tune adding 50whp, more in the low-midrange, and dampens low RPM torque.
- The stage 1 dampened first gear tune adding 50whp, more in the low-midrange, and 65wtq. This tune dampens first gear torque to help with traction.
Product Features:
- 5″ Touch Screen Display.
- Real-Time data display with multiple layouts.
- Easy to navigate menu system for settings.
- Store multiple tunes, including factory. Flash saved tunes without the need for a laptop.
- Note: Tunes are still created with the KTuner PC software.
- On Board Logging, record datalogs without the need for a laptop.
- 5 Programmable LEDs (RGB) for shift lights, warnings, etc.
- Bluetooth connectivity for peripherals and the TunerView Android app.
- This unit is locked to one ECU and allows you to alter the settings in your ECU.
- Return to factory at any time and unlock the unit to resell.
- This allows datalogging and reflashing right over your factory OBD2 port!
- Extended data parameters available on certain vehicles.
- Diagnose any Honda/Acura CAN vehicle, even when already locked to a vehicle.
- KTuner uses USB connectivity for fast data transfers.
How does the KTuner Touchscreen Work?
The KTunerFlash V2 features a 5″ touchscreen display that can show essential sensor data in real-time as a digital dash display. Though it’s meant as a handheld a simple Dual-T bracket can be added to allow mounting on a variety of inexpensive Dual-T mounts. Through a simple to use touch interface you can choose between different layouts, multiple data items, and even color options on layouts that support color changes.
Via full integration with our KTuner Tuning Software you are able to load the factory tune and multiple custom tunes to the KTunerFlash V2 allowing you to switch tunes without the need for a laptop. Easily flash back to factory with the touch of the screen. If you’re making quick changes or on the dyno you can also flash through the KTunerFlash V2 without having to upload the tune first.
5 Programmable LEDs can be set to show any combination of colors (RGB) and even allow for fading between a start and end color based on your settings. Customizable intensity settings for each breakpoint allow you to fade in or out at your desired breakpoints. Warnings allow an LED to flash rapidly to easily grab your attention. This can be used for shiftlights, an overheat warning, overboost warning, and other options.
KTunerFlash V2 features On Board Logging With Programmable On/Off Parameters for recording datalogs without a laptop! We allow up to 1000 datalogs to be recorded with no limit on length, so you’ll never miss a beat. Quickly enable or disable on board logging from the menu and once your parameters are met it will record all essential data for later review.
KTunerFlash V2 has built-in bluetooth integration. With a supporting app, like TunerView for Android ($5), you are also able to add additional gauge integration for real-time data display and more. The TunerView app allows you to use your Android device as a video camera and overlay real-time data from the KTunerFlash V2.
WATCH ME!!!!!!
