derbo904
Keeper of Blinky lights
- Dec 2, 2016
- 18
- 610
- 330
- Bay Area, CA
- 17 FK7 | 11 E90M3
- #46
93k miles and counting.
I don't get this comment. Where is all this $$ I put in? I barely put in $2k worth of parts outside of maintenance (I have a spreadsheet). Clearly a $23k MSRP EX will become a $36k CTR with $2k worth of parts. ROFL.Nice. But all the $$ you put in, you could have bought a CTR.
Honda Dealership. It comes standard on any civic with factory leather installed like a sport touring.Where can i get the leather shift knob?
Since my tires were starting to go, I figured I start hunting for a set of OEM wheels. I always wanted a sport hatchback but I wanted the EX features. I posted a few threads up to WTB touring, Si or Sport wheels. Luckily a local member here just got an Si and was about to take them off. We setup a deal and I picked up a set of Si wheels!
I was pleasantly surprised that the wheels were made by Enkei.
I really like that it is the polished versions from the sedan/coupes instead of the gunmetal ones. This seems to brighten up my hatchback as pure black darkness was a bit much.
Unfortunately no.Did you managed to weigh the wheels before and after? You went from 17" to 18"?
Today I tackled the steering wheel swap. It feels so much better that plastic thing not to mention looking a lot better.
Notes:
-The steering wheel bolt is on there good. 10mm Hex socket + a huge breaker bar did the trick.
-I bought two new airbag bolts and steering wheel bolt because they have dry green locktite on there. I would assume its only a one-time use bolt. They aren't too expensive at $11 for 3 bolts.
-When the steering wheel is removed, I saw there was two lines on the steering column splines. They matched two lines on the steering wheel. My guess is that it was marked to help alignment be simpler. It certainly helped me since the rotating black piece with the white peg could freely rotate when the steering wheel was off.
-When installing the battery again, the dash will light up like a christmas tree. A simple test drive will reinitialize everything and the lights will go away.
where Did you get the steering wheel?
This is pretty dope. I think i'm going to have to finally get my pics together and post everything I've done so far.
