Fatherpain’s 2018 Type R
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 66B0BFDB-532E-4132-B629-E57CD8F3E035
Ok here is the J's Racing Front Wing Spoiler Lip install. First step is to remove the bumper which has been previously covered here. However will briefly recap for the purpose of this install. Recycling a couple pix until I remember to take updated ones. Remove all of the plastic fasteners and bolts, then disengage the airbox rubber seal from the cooling plates. Remove the plates and set aside.
Honda Civic 10th gen Fatherpain’s 2018 Type R B3BFB519-8ECA-40D8-9FDF-308E49D94D50
Remove the rubber hood seal. Be care not to lose the plastic pins, which easily fall out.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7341E772-AF56-4D3C-A67C-B6A3A7A6F979
Raise the car using some sort of jack or lift. Block if needed to ensure there is no way for the car to drop while you are underneath. From under the car, remove all of the plastic push clips that secure the lip, by popping the head with a flat screwdriver then lifting out.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8C84EE62-0B89-4589-B524-BE4E9E143DA9
Remove any bolts using a 10mm socket. Some may use Allen head screws. This isn't the lip, but these will need to come out also, to remove the plastic under tray. More on that later.
Honda Civic 10th gen Fatherpain’s 2018 Type R 64731DE4-603F-49CF-BF52-F7DF59BCF3AC
Remove these (2) Phillips screws on each end.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9D002C91-BEB6-49E1-83AC-4B577DAF8DE1
Then remove these (3) screws and repeat for the other side.
Honda Civic 10th gen Fatherpain’s 2018 Type R 456DE955-6B39-4B34-9284-AAC3DC099AC2
Reach behind and gently pry this corner of the bumper out. Once it separates, stop.
Honda Civic 10th gen Fatherpain’s 2018 Type R 660977EC-5266-4E19-A253-6D840F260D7F
There are (2) plastic tabs under the headlights that need to be depressed to release the bumper. Lightly pull the corner that was released in the previous step to provide some extra room to insert a small flat screwdriver or pick tool.
Honda Civic 10th gen Fatherpain’s 2018 Type R 5A4CDC13-A6C7-4AF2-9805-C1AAC62CC7DB
With the tabs released, the bumper will pull away a little.
Honda Civic 10th gen Fatherpain’s 2018 Type R 107736C9-0E72-4AA8-A18E-ECCD45841F07
There are (2) tabs on the eyebrows to release as well... Then the bumper should be completely free.
Honda Civic 10th gen Fatherpain’s 2018 Type R 01E4B05A-3847-4E13-A258-B0F925D6697D
Now carefully pull the bumper off. I like to have something ready to set it on. Stools can come in handy. The EZ car lift is ideal for this job, as the lift is adjustable to any height using the drill input. I like to have the car set just above the stools before removal. My bumper is pulled back this far, because I have fog light extender cables… So be careful how far you pull yours back so not to snap the OEM fog wiring.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8FD36A8D-B3C5-463C-A9D9-B96772F3671A
Disconnect the fogs then the bumper is ready to fully remove. Be careful not to let the bumper fall forward while doing this.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7E0014C1-D643-40DE-8FE9-028449802E09
Bumper and OEM lip removed. Advise setting on something soft to avoid scratching the paint.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 719BEDCA-17A4-4132-94EB-23D6CD8B556F
Gently lay the bumper onto it’s face.
Honda Civic 10th gen Fatherpain’s 2018 Type R 71474455-8100-431B-B31B-A238F9DEE8CA
Use a 10mm socket to remove these (2) bolts securing the OEM lip on each side. Save to reuse later.
Honda Civic 10th gen Fatherpain’s 2018 Type R 783BEFC9-68F1-4CBA-BCAF-9302844828B9
Then gently separate the lip from the bumper.
Honda Civic 10th gen Fatherpain’s 2018 Type R ED844A44-A8D4-4084-9167-89CF9FDDAF92
There are a bunch of black plastic tabs that secure the OEM lip to the bumper. Press to release and push through. Start at one side…
Honda Civic 10th gen Fatherpain’s 2018 Type R E3620561-6734-440E-9718-A64C54D85D66
Work your way across the middle intercooler section.
Honda Civic 10th gen Fatherpain’s 2018 Type R 38B1491C-D08A-47E5-BC24-BA6D122CE11E
And do the same for the other side.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1FB0DFAB-D41C-4751-9A21-6B556E287E44
With all tabs free, pull the lip from the bumper.
Honda Civic 10th gen Fatherpain’s 2018 Type R 40E4D061-6EC3-4BE7-B61A-27574C173F76
J’s Racing Front lip spoiler and under tray side by side with OEM lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 19798517-36C4-4481-9CFE-042E43BCD907
Slide these (2) reinforcement clips from each end of the OEM lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 07761967-FC04-4B17-A528-C85F1CD642F7
Use a pliers or channel locks to squeeze them once they are off. This will prevent them from being loose and sloppy on the J’s lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 78EB7613-5F39-4736-A084-5FFCA05D5F45
Then slide them onto the J’s lip in the same orientation they were on the OEM. The threaded end should be towards rhe outside.
CJizzle_FK8
CJ
Monterey Bay
2019 Honda Civic Type R
Quick question. I noticed you kept your inlet pipe stock. I'm seeing this in a lot of heavily modded type r's. Any reason for that?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 033C53A3-DB0A-458D-96BB-57A62584EFEF
Hi CJizzle,
Apologies for the confusion. Was recycling a couple older photos of the engine bay to expedite the J’s lip write-up.
Originally was not going to cover bumper removal, as the J’s instructions starts with the bumper off + I’ve previously covered that… however after thinking about it, decided to include it, so some of the engine bay pix are just place holders until I get time to replace with new ones.
The above picture is the current state of the engine bay. Inlet turbo tube is actually the updated Eventuri V2.1 CF. ;)
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 7CF629D3-E050-479F-B3BD-03226253D5A9
Here are the provided instructions for the J’s Racing front lip spoiler install… followed initially but led to abit of re-work. Please see my suggestions for a smoother install highlighted in yellow. ;)
Honda Civic 10th gen Fatherpain’s 2018 Type R F1F2960D-F68E-4344-9659-197CA65F6869
Will demonstrate these steps in the subsequent posts. :thumbsup:
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R C69B1690-4BC7-4A5A-BEC4-074BF45D04D4
The first step of the installing the lip is to perform a test fit and locate (4) 7mm and (2) 20mm holes to drill in the bumper. Align the lip to the bumper. Was able to do this solo, but a 2nd person would have made things a little easier.
Honda Civic 10th gen Fatherpain’s 2018 Type R A189B445-73C7-4B7C-ADE5-1186AB3C5042
Before pressing the lip into the bumper, make sure all of the tabs are lined up.
Honda Civic 10th gen Fatherpain’s 2018 Type R A96B1790-B801-4A88-B27C-E5CABBF1D388
There also are a bunch of tabs along the intercooler opening.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8D3B46DE-1C5F-4528-A3F5-9ABD3360FF4A
Remove both plastic vents from the bumper by reaching your fingers through the finger openings then pulling the vent away from the bumper. (2017-2019 vents shown).
Honda Civic 10th gen Fatherpain’s 2018 Type R 55BFBF64-687A-4EEB-9488-0BFA86E92BDA
Then pop this push clip with a flat screwdriver to release.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4BE401A4-6552-4183-982D-737D7060064A
Vents removed, allows you to grab hold for leverage to squeeze the lip and bumper together. Smarter not harder! ?
Honda Civic 10th gen Fatherpain’s 2018 Type R 9828F5F1-B4ED-4558-BDDC-03D8B357074C
Another thing that worked well was to angle the bumper like so…
Honda Civic 10th gen Fatherpain’s 2018 Type R E254E21E-9AD7-49DA-91C9-83DAD29A91F8
From this vantage point, can check to see whether the tabs were properly inserted before fully seating.
Honda Civic 10th gen Fatherpain’s 2018 Type R D402CCDD-FBA4-459A-A0BA-C1D58E641FE2
This is the correct amount of engagement.
Honda Civic 10th gen Fatherpain’s 2018 Type R B3716880-92D6-4AA2-BD89-45F7AA464457
Make sure the tabs are secure.
Honda Civic 10th gen Fatherpain’s 2018 Type R 5068DDA1-EF24-4ED4-84AB-2C15FA0FD3F3
This is the correct depth across the intercooler tabs.
Honda Civic 10th gen Fatherpain’s 2018 Type R EDED98EB-A720-4B26-BA77-B6E6A2C416F3
Finesse both sides of the lip around the edge of the bumper.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0F6632D9-2787-49D7-8205-AEE6C85E974A
J’s Racing front lip temporarily installed. Make sure everything looks symmetrical, then the next step is to mark and drill bolt holes. :thumbsup:
Sam3
Sam
2021 CW CTR
Today I met with @fatherpain and @boosted180sx, and they are two of the kindest, coolest, and most knowledge people I've met. They helped me deal with a boost leak problem that ruined my track day yesterday at Buttonwillow.
I got a new Sequence Manufacturing exhaust to help me hear the engine RPM at the rack, while at the same time avoid an obnoxious morning growl that would upset my neighbors and dealing with drone while cruising at the freeway. It's a valved exhaust that opens with boost. I had a Honda dealer service center install it for me.
Within the second lap of my second session, the car went into limp mode. It lost most of its power and I had to complete a lap I just started at slow speed. Scary situation knowing that cars are coming very fast behind me. The dash was showing all kinds of error messages. I had just topped the gas tank right before the session and the car temperature was normal. So it cannot be related to fuel starvation or overheating.
Honda Civic 10th gen Fatherpain’s 2018 Type R LimpMode
After reading the code through an OBD reader at the track, it turned out to be P00299. The car wasn't getting enough boost.
Honda Civic 10th gen Fatherpain’s 2018 Type R p0299_detected
I knew it must have something to do with the new exhaust because that's the only thing that changed in the power train. Everything else in it is stock. So I had to cut my track day short and head home. While driving back from Buttonwillow, the car went into limp mode again, and I started to get a rattle the next morning.
Then I met with fatherpain and boosted180sx. They let me drive their beautiful FK8 thoroughbreds to compare with mine since they also have the Sequence exhaust. I could immediately tell their cars are louder than mine. They drove my car and concluded that there's something wrong with the exhaust because it doesn't seem that the valve is opening. Boosted180sx also noticed that the exhaust tips shifted all the way to the left.
Fatherpain put my car on his lift to see what's going.
Honda Civic 10th gen Fatherpain’s 2018 Type R on_ezcarlift
Upon further examination, they discovered that two of the muffler cylinder holders were installed backward, one of the slip joints wasn't complete fitted, and some of the holding screws and clamps were loose.
See how the tips are shifted to the left.
Honda Civic 10th gen Fatherpain’s 2018 Type R Shifted_exhaust
They tightened the screws and shifted the tips to the middle. That took a lot of effort because some of the exhaust pipes had to be loosed and rotated and the fasteners loosed and pushed to the right.
Here's Fatherpain and Boosted180EX discussing how to best center the exhaust and fit everything as it should be.
Honda Civic 10th gen Fatherpain’s 2018 Type R discussing_centerin
After they centered the tips, installed the muffler holders correctly, and fastened everything, they went about diagnosing the boost leak.
Tips centered.
Honda Civic 10th gen Fatherpain’s 2018 Type R exhaust_centered
Fatherpain used his boost detection tools to find out where the leak is coming from. He pumped compressed air through the inlet pipe and he and Boosted180SX checked all points where a leak could happen by placing a liquid at those joints and checking for bubbles. No boost leak could be seen in the engine bay.
Honda Civic 10th gen Fatherpain’s 2018 Type R boost_leak_check
Then they went about diagnosing the valve problem. They discovered that even while putting 20 psi of compressed air through the system, the valve is only half opening.
Honda Civic 10th gen Fatherpain’s 2018 Type R valve_half_open
After adjusting valve screw, fatherpain was able to get it to fully open at around 5 psi and then close when there's no pressure.
Honda Civic 10th gen Fatherpain’s 2018 Type R valve_open
Either the screws came maladjusted from the factory, or the dealer could have adjusted them incorrectly.
Then Fatherpain cleared the code using his Autel OBD tool.
Honda Civic 10th gen Fatherpain’s 2018 Type R resetting_p0299
Afterwards Fatherpain and Boosted180SX drove the car and they noticed that it sounded like the valve is functioning,. Of course it still doesn't sound as loud as theirs because they're tuned and have some bolt-ons.
After I left, I drove the car for about 120 miles, including a spirited run on a lightly trafficked highway for the time. The valve seems to be functioning, the car feels like it has slightly more power, there's no more rattling, and I haven't gotten any more underboost errors. It seems that they fixed the problem! I hope it stays that way, especially at the track.
After driving their cars, hearing the sounds, and feeling the extra power, I'm very tempted to accelerate my slide down the slippery slope of modding and tuning the car :)
Doc_Mello
2019 CBP Si Coupe
Awesome tuner community! ?????? Man, I wish the world worked this way!
As for the slide down the slope, it’s a fun ride. ? Enjoy every minute of it!
fatherpain
fatherpain
Tom
Glad we are able to get it straightened out. Pretty cool that my master @boosted180sx was able to make it out to help. Happy to hear it sounds like it’s fixed..
Felt like
Honda Civic 10th gen Fatherpain’s 2018 Type R 6B1FB261-2095-4D09-8ED9-A74C79D41075
When it comes to the FK8, me and @boosted180sx be like…… ?
Afterwards, Fatherpain…..drove the car and noticed the valve is functioning,. Of course it still doesn't sound as loud as theirs because they're tuned and have some bolt-ons.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 4E1C4326-0E96-4333-80A8-B002E46CD9F1
With the lip test fit complete, the next step was to mark bumper holes for drilling and enlarge the lip and under tray rivet holes as they arrived too small.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2B6E55F7-55C5-4492-8A47-B91B08DC3AD9
Found it best to keep the bumper flipped upside down.
Honda Civic 10th gen Fatherpain’s 2018 Type R 30A29EC6-87FA-4C5E-B29A-6933331D0F01
Then holes to be marked and easily seen. There are (2) 7mm holes under each vent.
Honda Civic 10th gen Fatherpain’s 2018 Type R EBE75CA3-F716-4B0B-93E4-5CF9F336E2C9
A fine tip sharpie works good for marking the center of the holes. This is a close up of the outer one under the a vent.
Honda Civic 10th gen Fatherpain’s 2018 Type R 469431AD-0629-42D6-82A6-9D2169237C87
Here is the innermost 7mm hole. Notice the bumper mold is directly above.
Honda Civic 10th gen Fatherpain’s 2018 Type R 792E9D54-0665-46A9-82A3-7A574A17D27A
This bumper area above these inner 7mm holes are where to mark the (2) 20mm ones.
Honda Civic 10th gen Fatherpain’s 2018 Type R 73D6629B-F40A-4ABD-AD0D-9C9ACDD9A877
Eye balled as best I could to line the 20mm holes directly above the inner 7mm holes. The outer ones do not need this.
Honda Civic 10th gen Fatherpain’s 2018 Type R DFE1818E-005E-4AEE-8027-49E7D0D80937
After all holes were marked, used an awl to create a starting point for the drill bits. Here is one of the 7mm holes.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9684B853-36E1-47B1-941E-7E32E171E9F6
Here’s one of the 20mm holes.
Honda Civic 10th gen Fatherpain’s 2018 Type R D2DE99D5-C67A-4D71-9D74-1F36DCD7444F
With all holes marked and pricked, flipped the bumper over and pulled the lip back off, in preparation for drilling. :)
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R FA83C397-CEFF-4D37-9252-4C365667D50E
These are (3) drill bit sizes needed:
  • 1/8” - to enlarge the provided river holes on the J’s lip and under tray…also can use to make pilot holes for the larger sizes and to drill out rivets if needed.
  • 1/4” - for the (4) 7mm bumper holes.
  • 29/64” - for the (2) 20mm bumper holes. As this is big, will need several sizes in between, to incrementally drill larger holes until reach 29/64”.
To avoid tearing the bumper, lip and FRP under tray… recommend lowering the drill motor setting to 1 (lowest) and drilling slowly.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3572F0FE-D9CC-4151-AA04-E5CDA2DA0226
Flipped the bumper back upside down. The bumper prevents drilling the 1/4” holes under the vent straight on…No worries
Honda Civic 10th gen Fatherpain’s 2018 Type R 9F427DC2-CEDF-4560-9C24-22CA2514A389
The bumper is pliable and easily pulled out of the way.:headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R 9A35C7FB-A296-4B78-9C0F-0D10EEA5C1C7
For the 20mm, I used a variety of drill bits to gradually enlarge the hole until achieving 29/64”. If don’t have access to this assortment of large bits, can cut the holes using the heater blade trick. They are just access holes, so don’t need to be perfect. :cool:
Honda Civic 10th gen Fatherpain’s 2018 Type R 2849E59E-86D0-4729-B988-D5FF564326BC
Gradually drilling the 20mm access holes with a smaller bit.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2F1B3A64-80DE-4D89-A9CF-F2CC6C68B40D
Using the 29/64” bit. Remember: drill slowly on setting #1. When the bit stalled, backed off then hit it again.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3656F945-FA78-4199-9C85-71A5E36A476E
Boo yow! 20mm hole drilled, perfectly centered to access the innermost 7mm bumper hole. :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R 6EE7D53C-713A-4163-8F9C-C27F01C9B7FA
All of the provided rivet holes on J’s lip need to be enlarged using a 1/8” bit.
Honda Civic 10th gen Fatherpain’s 2018 Type R ACD85AD5-1C7F-4B39-848B-0A20B545769B
And all of the river holes on the FRP under tray as well.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R D26EE3CC-C3C7-4866-82B9-FA3FA22FED46
Here are the mounting fasteners included in the J’s Racing lip. Highly recommend adding (4) lock washers to prevent anything from vibrating loose.
Honda Civic 10th gen Fatherpain’s 2018 Type R 76689857-3827-407C-BEB9-C5662CB8B886
This is what a complete fastener set looks like. Bolt, 2 washers, lock washer and nut.
Honda Civic 10th gen Fatherpain’s 2018 Type R B3E49FCE-6060-46A2-B029-08D7F062F39D
It's also a good idea to have plenty of these plastic push clips on hand. They are fairly cheap on websites like Honda Parts Now.
Honda Civic 10th gen Fatherpain’s 2018 Type R 6CF037EF-6C8A-42E2-ADF4-97F4CBF5C8EA
These are also good to have on hand.
Honda Civic 10th gen Fatherpain’s 2018 Type R 063ECFAD-369A-4298-BAE5-3BE1F1DA43A0
With all holes drilled, it's time to reinstall the lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9227E4AC-7E8D-4E13-A5FC-20E786C27AB3
Always good practice to apply anti-seize to bolt threads before installing.
Honda Civic 10th gen Fatherpain’s 2018 Type R F24C647B-5539-4AFB-8485-F6DE8BBA288E
With the lip reattached and tabs fully engaged, the (4) M6 fasteners install to the 1/4" holes to secure the lip to the bumper.
Honda Civic 10th gen Fatherpain’s 2018 Type R 512375FD-4B9C-41BA-B75F-D843BF69A8DB
The (2) outer fasteners are easy to reach, provided the FRP undertray is not installed. This nut still needs to be tightened. Should be snug but not overtightened to prevent cracking of the bumper or carbon fiber lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 48F2C178-C5E5-47FD-B166-0288CC96DF19
The innermost fasteners are a little hard to reach, so needle nose pliers make things much easier. :)
Honda Civic 10th gen Fatherpain’s 2018 Type R 6B0D34AD-E064-4E52-B55A-5C4672FE8A80
This is the reason for the 20mm holes. Without them, it would be much harder to thread a nut onto the M6 bolt, however it wouldn't be impossible.
Honda Civic 10th gen Fatherpain’s 2018 Type R EDC278D5-E3C4-4AB3-8AFD-06C99E899542
Innermost M6 fasteners installed. :p
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 60938932-1443-4DDA-8FCA-C6BDC5B60CA2
Make sure the ends of the J’s lip fit like this.
Honda Civic 10th gen Fatherpain’s 2018 Type R FDF7DE19-6205-4090-B26D-9D5CD16126AD
Verified the hole in the lip lined up with the threads on the bumper. This side was perfect.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7DA7DAE7-6D13-4A68-8436-28F60E8FB1BA
However the otherwas a little off so required adjustment.
Honda Civic 10th gen Fatherpain’s 2018 Type R C02A5774-2F4A-4752-8574-7E2FA6DDCB18
A round file worked like a champ to elongate the hole in the J’s lip.
Honda Civic 10th gen Fatherpain’s 2018 Type R 6A30A499-B1FB-416B-AEA1-84D5B469AAD0
Lip and bumper hole ready for OEM bolt removed from the stock lip to be reinstalled.
Honda Civic 10th gen Fatherpain’s 2018 Type R F32A6D00-FF97-436C-B300-B8935F22B20E
make sure these holes and the threaded clips on the lip are also lined up.
Honda Civic 10th gen Fatherpain’s 2018 Type R 104A6EE8-7D7F-4BDB-94B9-FF962A4340EA
And reinstall the OEM bolts.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 46D4BD0A-D5D0-4FEE-B5FE-F03AECC5438D
With all bolts installed, the FRP under tray was ready to go on.
Honda Civic 10th gen Fatherpain’s 2018 Type R 35430DC5-3AD5-43C3-ADA6-EB8F6619792A
The edge of the under tray tucks inside the CF lip and sits flush.
Honda Civic 10th gen Fatherpain’s 2018 Type R 3F72FD70-F04C-4F8D-8929-F1DC1391CA72
Used several plastic push pins to temporarily hold the under tray to the bumper for the rivet installation. These push pins need to be removed to connect the OEM plastic under tray before the bumper goes on. (more on that later.)
Honda Civic 10th gen Fatherpain’s 2018 Type R 1F7CFB35-C623-4EE0-9838-0979E617F94E
Inserted all (11) rivets into the lip and under tray to protect against misalignment while compressing each one.
Honda Civic 10th gen Fatherpain’s 2018 Type R 009636DC-079C-4293-BE60-20BC4F915348
This is a nice rivet gun available on Amazon for about $20. But any will do..
Honda Civic 10th gen Fatherpain’s 2018 Type R D577D149-05C6-45D3-AACC-8C3E8EA4E2C4
Correct orientation of a rivet that joins the under tray to lip. The diagram that come with the lip, show opposite, which was confusing
Honda Civic 10th gen Fatherpain’s 2018 Type R BA64E5ED-5AD1-4E2A-A01C-A685A5DC1680
The gun tip goes onto the needle while the rivet end passes through. These pics were from my first attempt, before realizing the under tray needs to go on after the bolts go on. Original instructions said to put it first. ?
Didn’t take new photos, so please visualize doing this with these pieces on the bumper instead. :hmm:
Honda Civic 10th gen Fatherpain’s 2018 Type R E5DD8263-DB33-46D3-AFE0-8C33964078C4
Fully press the gun down so the tip is flush to the work. Make sure the FRP and CF are snug against each other.
Squeeze the handle, to draw the needle up and expand the rivet. Be sure to wear eye protection because the wire snaps off when it’s done.
Honda Civic 10th gen Fatherpain’s 2018 Type R E3284FB5-CCCD-42DA-A1EB-8A1FE5B858BA
Rivet installed. Repeat for the rest.
Honda Civic 10th gen Fatherpain’s 2018 Type R EC2B5D25-8337-45D9-BB9F-0995B2D3B9D0
FRP under tray installed in the proper sequence. After the bolts are installed, otherwise it’s super hard to reach them.
Honda Civic 10th gen Fatherpain’s 2018 Type R F800DABA-6DD0-452E-A33F-E8C71675AE36
Could have done it that way, but it was stupid hard and required a lot of patience and finesse to get to the bolts. Not good for the average DIYer. Wanted these instructions to be painless as possible, so removed the rivets to do it right. If curious or need a redo, this is done by drilling the aluminum rivet using a 1/8” drill bit.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7AFF3C78-0A09-4735-BF3C-DBE56CAA6213
Nice and slow, until the rivet breaks free.
Honda Civic 10th gen Fatherpain’s 2018 Type R 5E6F8248-1297-40D4-824C-884C326A0CD5
Drill through until the other end of rivet comes loose.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 69B0BA36-53B2-4F67-91A8-91534EC60B6B
The J’s Racing lip instructions say to “sandwich” the OEM plastic under tray that’s still on the car between the bumper and J's FRP under tray at this section when reinstalling the bumper. Found this was also incorrect. :doh:
Honda Civic 10th gen Fatherpain’s 2018 Type R D34F244A-9075-4562-B18A-B614A4C91272
This is the intended “sandwich meat” if you will. There was no way the bumper would go on that way. :rolleyes: So went about removing it. I normally disconnect at this section when pulling the bumper anyways, so when placed on the ground, it will remain upright and not fall over.
Honda Civic 10th gen Fatherpain’s 2018 Type R 1A9B690F-1869-41FD-A64E-17C1CD054EBF
To pull it, there are a bunch of these push pins that need to be removed. The pins towards the bottom of the photo, do not need to be removed as they just hold the rubber skirt that runs along the bottom.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8B48CE5F-1287-4089-A3E0-EC20D1C11801
There are several bolts to remove. Some reside in deep recesses (not pictured). 10mm is the socket size.
Honda Civic 10th gen Fatherpain’s 2018 Type R 34FA2960-E796-4669-921C-B3F221D329BB
Finally, there are (4) of these smaller push pins.
Honda Civic 10th gen Fatherpain’s 2018 Type R 34383510-BCB9-4B3E-B5F9-00ABA09E7D2B
OEM plastic under tray removed. :) Just be careful when underneath as it collects pebbles and dirt so wear eye protection.
Honda Civic 10th gen Fatherpain’s 2018 Type R 2394B031-B0C7-44F1-BDB9-D899061D6AE5
Again, smarter not harder. Its much easier to install the bumper to the plastic under tray off the car.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9BF389B2-4611-4690-8FC2-EB1181A56BCA
Positioned the bumper this way to install the under tray. Placed on a soft blanket to avoid scratches.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7D4F6531-4FB6-4877-A524-EF5B41692732
Again, this is a close up of the area the instructions say to sandwich the OEM under tray in between. Notice how the OEM undertray has a recess for the white bumper to sit against.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7819545A-E7A6-4C6B-B4C2-77EE2D79C963
OEM plastic under tray aligned to the bumper.
Honda Civic 10th gen Fatherpain’s 2018 Type R 358BF65B-BDD3-4C1B-AEC1-84009B362E53
Ensure all of the holes line up.
Honda Civic 10th gen Fatherpain’s 2018 Type R F8D640CC-0D5F-4FDA-9649-3B3EFE9FDD22
Then install OEM push pins to lock it together.
Honda Civic 10th gen Fatherpain’s 2018 Type R DC7A4929-E7C8-446C-9A1A-AA9FD955B81F
OEM plastic under tray installed to the J's lip and bumper! Darn this is finally ready to go on. Woohoo!! Hopefully it's worth it ?
