LTW Project - warning ugly car inside
Myx
Delaware
37 lbs (actually kind of light).
Thanks! Was hoping they were 40lbs+. May be removing them for some test and tuning times. Trying to get to a specific power-to-weight ratio for drag racing testing. Thanks!
RS27
RS27
Justin
Honolulu, HI
2018 Civic LX Sedan 6 spd / 2019 Civic Coupe Sport CVT / 05 E46 M3 6MT Slicktop
Another project today.
Removed heater core and gutted under side of dash.
Good for 6 lbs.
The freaking heater core is feather light, 1.2 lbs!
Funny I was planning on the A/C delete when pulling the dash and heater core, but being it’s summer time, I kept it (for this year at least).
Plus the right way to do A/C delete on the K20C2 is buy the Canadian idler pulley (from the Canada DX with factory delete) that take place of the compressor. I haven’t found one to buy yet. That is where all the weight is at. The condenser, blower box with air mix motors, evaporator and expansion vale and A/C lines are max 20 lbs. compressor alone is probably 15lbs.
The dash gutting went remarkably well. It looks cleaner, and the A/C can only blow from center of HVAC blower box and upward. so it hits the dash under side and bounces toward me. Effective haha.
Attached some pics of progress today. The heater hose delete we just looped and chopped the line off the driver side of the head. Just under my red intake boot. Worked well.
Honda Civic 10th gen LTW Project - warning ugly car inside E8D3D8D1-3281-49EB-AB4C-373F74E00B39
Honda Civic 10th gen LTW Project - warning ugly car inside F66DB318-E836-48F2-BF80-DCB0DB6E84EA
Honda Civic 10th gen LTW Project - warning ugly car inside 38CD52D1-4523-433A-AE61-2E88EF16E052
Honda Civic 10th gen LTW Project - warning ugly car inside C3997CDB-3279-4874-87E4-A487EDACE34D
Honda Civic 10th gen LTW Project - warning ugly car inside 2813E5E4-7963-46F5-B900-A227A4F6FE8D
Honda Civic 10th gen LTW Project - warning ugly car inside 4CEA0C7D-664E-45B3-9F00-B62AF8824739
Honda Civic 10th gen LTW Project - warning ugly car inside C1E338AA-E3BA-4311-95F9-F1C5FBC0223C
Honda Civic 10th gen LTW Project - warning ugly car inside F1C2A2F5-9610-4783-A3DE-86D509C57A33
RS27
RS27
Justin
Honolulu, HI
While in there we changed engine and cabin filters. For the SECOND TIME and my car has just under 19k miles. Honda says to change those every 25k. Mine are filthy every 8-10k. Cheap and easy to do so may as well swap them.
Did my annual service 2 days ago. Honda genuine 0W-20 Full Synthetic and this year I changed the Brake Fluid and the MTF with Honda fluids. Wiper inserts also.
So the dash beam and add on brackets are not liking the open salt air. Corrosion on surface. I think i can take car to metal working shop to saw off and smooth all the brackets I don’t need off the beam. That should save 8-10 lbs and then I’ll sand and paint the beam black. At same time, I’ll gut the stereo wiring off the harness and clean that up around HVAC control panel. Will probably mount same panel on underside of dashboard.
Kendall
GA
2019 civic type r
RS27,
Great post! I’ve read everything you posted so far on your weight loss adventure and joined the forum because of you. I’ve done similar projects on 3 Mustangs and now my civic type r. The type r to a lesser degree to preserve the warranty and creature comforts. I’m 40 and live in Georgia so Humidity for me and my 8 year old requires AC.
Exhaust systems for my car are way over priced and I don’t believe much performance gain will gained with a stock car (except Injen cold air) from doing just cat-back (preserving the warranty), so I chopped of my mufflers and did a turn down. I saved 25 pounds.
Honda Civic 10th gen LTW Project - warning ugly car inside 0B2CAEC9-EDE0-446F-AA2B-8CB5F43B71C4
RS27
RS27
Justin
Honolulu, HI
^A lot of weight to be lost with the huge muffler the R comes with, good idea.
Sorry for lack of update guys, I did gut some more dash and order the Invidia so I'll get the small weight loss benefit and maybe added power, I'll update when that is installed with pics and new total car weight, Should be 2,440.
Edit: also bought a house in Honolulu, so the time hasn't been around for the car as much, just a one car garage and the wife and I have two cars, so mine hit the street in front ?
Kendall
GA
2019 civic type r
I also went with RPF-1 wheels in 18” about a year ago. Best bang for the buck over the stock 20”
RS27
RS27
Justin
Honolulu, HI
^RPF’s would be my first choice on the budget front if I bought a FK8.
…..speaking of I almost did haha. Local had a 17 one owner CW with 16k miles for $37,800. But I bought $35,000 in Ford Stock and $33,000 in Rivian. So there went my funds.
In my car news, I found a unicorn for a great deal. OG TE37’s in Hyper Blue in the ultra rare 15x7 with 5x114.3. A bit small for the 10th cars, but my car doesn’t care about looks lol. My scale is a bit off, but they are between 10-10.8 lbs per wheel from my research online. Comical picking them up, they are so light. Tire size is under size though. Only option with sport intentions is 205/55. Which is over an inch shorter than stock.
Luckily! I bought some Bilstein B14 coil overs from Tire Rack I’m getting this week.
Wife’s coupe got ceramic tinting with a tint strip and I purchased the same Etsy blackout side chrome trim delete tape. Also planning on carbon fiber H badges and she will get my RPF’s and my Eibach springs. Lightening her car and making it cooler! (Pun intended haha). The stock 18” Sport wheels are something like 28 pounds EACH. The Goodyear eagle sports are 25lbs each. Insanity. So my 13.7 lb RPF’s should drop about 19 pounds PER CORNER. I can’t say I’ve ever dropped that much before. I told her she should get about 3mpg better. Which should offset some Brandon gas price increases. :rolleyes:
Honda Civic 10th gen LTW Project - warning ugly car inside BA558FF4-D946-480D-9F64-95824DF9E0C9
Honda Civic 10th gen LTW Project - warning ugly car inside EC5607C4-0784-48BF-AD55-8B7A26202805
Honda Civic 10th gen LTW Project - warning ugly car inside 3356956E-B526-42CD-A59D-9A1E69AE484D
RS27
RS27
Justin
Honolulu, HI
Oh and as seen in the Volk pics, they have some small kine curb marks. Anyone know who could match the Hyper Blue color of these? Looking for a touch up paint amount. Not worth refinishing this nearly 20 year old finish for a couple curb marks.
Myx
Delaware
I am foaming at the mouth over your wheels weight. Simply WOW! Wow, Wow, Wow..... Congrats!
As for your tires, what was the size of the tires that were 'undersized'? I'm interested in the size and model it is as opposed to the tires you will have fitted on it. I went with 205/50-15 Vredestein Quatrac 5 on my Civic. Lowers the car significantly. The weight was 17lbs (4lbs less than stock).
Stock final drive gear ratio is: 4.81:1
Vredestein Quatrac 5 Tire gear ratio: 5.31:1 Gear Ratio Calculator
Miata Tire Size Calculator shows a -9.4% change from stock and a -1.7% from current setup.
Their only purpose was for lightness and acceleration. That 17lbs (or less) with the increased gear ratio, combined with your 10.8lbs wheels. Oh my......... I know you like grip though. :p They are grippy.
RS27
RS27
Justin
Honolulu, HI
^205/55. 19lbs each.
sneak peak of the rear Bilstein PSS kit with the adjusters completely removed. The car is about 1.5” lower than the eibach pro kits. I can really tell when standing next to the car where it sits next to me. Keep in mind the two finger gap is fully slammed, my car just has so much weight reduction and undersized tires. Should still settle a bit from this pic. Which also shows the TE’s. They are *very* blue haha.
in other news. TIRE RACK IS WRONG in showing the Bilstein PSS kit they say fits the coupe and sedan. It very clearly shows hatchback only on the Bilstein USA website. So we had to reinstall my stock front struts and Eibachs because CLEARLY a 52 MM bottom front strut insertion diameter WILL NOT fit the sedan and coupes 50.5 MM. pretty upset about this issue.
Honda Civic 10th gen LTW Project - warning ugly car inside 88537EC9-0D34-41D8-834E-B1F33D2CA567
RS27
RS27
Justin
Honolulu, HI
LifPo battery from Ballade with the Type R battery cage dropped 19 lbs!!
so with the TE’s I’m down to 2420. Allmosstttt to the 23XX’s. Stoked.
Honda Civic 10th gen LTW Project - warning ugly car inside 47F40C8A-00A1-4A7E-8E3A-463388DAEF9C
Honda Civic 10th gen LTW Project - warning ugly car inside 7E8DEE11-2C90-4F19-95F3-70E5AF7CAEDD
RS27
RS27
Justin
Honolulu, HI
And tire rack refunded my money for the Bilstein PSS kit. It fits rear though so I got that for just the cost of labor to install. Now I’m on the hunt for a good deal on Eibach Sportlines so I can split the kit and use just the fronts. I’ll then need some shortened, stiffer Struts for the front.
ebatr24
Oregon
This is an awesome thread, your in fit territory for weight, I always thought the fit was a fun car that just need a slight bit more power.
