What format are the audio files in?I have a problem, USB port in the console compartment doesn't work with any flash drive, only works for charge, but does not play any file audio, is it normal or is a issue?
Drive works in front USB, but in console doesn't, the display indicate that there isn't any device connectedDoes the display indicate that there is a USB device connected? Does the drive work in the front USB? The manual indicates the console USB should play the files.
It is! I even tried with 4 USB flash drives 2 formatted in FAT32 and 2 formatted in NTFS and still does not workAlso make sure the USB flash drive is formatted in FAT32 format and not NTFS or anything else!
Have you tried multiple flash drive to see if it is just THAT drive, or if it is the USB port?
I had the same problem. For some reason the drive won't mount on it's own so here is the fix. Select SETTINGS, SYSTEM, scroll to the bottom to select DETAIL INFORMATION. Scroll down to select STORAGE. Scroll down to see the three possible USB storage locations. I believe 1 & 2 are the ones accessible to us in the cabin. The USB port that has your drive connected to it will give you the option to MOUNT USB STORAGE. Select this and voila you are in business. It is frustrating why the drive won't mount itself though.I think so! thank you
You're talking about the one below the cup holder, right? Does the one that is up-front ahead of the shift lever work?I have a problem, USB port in the console compartment doesn't work with any flash drive, only works for charge, but does not play any file audio, is it normal or is a issue?
I tried this but it won't mount. It does acknowledge the presence of my flash drive (which also lights up to indicate it's connected) but went I push 'mount', there's a short delay and nothing happens. Thoughts?I had the same problem. For some reason the drive won't mount on it's own so here is the fix. Select SETTINGS, SYSTEM, scroll to the bottom to select DETAIL INFORMATION. Scroll down to select STORAGE. Scroll down to see the three possible USB storage locations. I believe 1 & 2 are the ones accessible to us in the cabin. The USB port that has your drive connected to it will give you the option to MOUNT USB STORAGE. Select this and voila you are in business. It is frustrating why the drive won't mount itself though.
I think HondaMan put the finger on it. This has to do with the formatting.Also make sure the USB flash drive is formatted in FAT32 format and not NTFS or anything else!
i have to mount mine every time i start my car and it's a major hassle going thru multiple menu levels.I had the same problem. For some reason the drive won't mount on it's own so here is the fix. Select SETTINGS, SYSTEM, scroll to the bottom to select DETAIL INFORMATION. Scroll down to select STORAGE. Scroll down to see the three possible USB storage locations. I believe 1 & 2 are the ones accessible to us in the cabin. The USB port that has your drive connected to it will give you the option to MOUNT USB STORAGE. Select this and voila you are in business. It is frustrating why the drive won't mount itself though.
