It's when your turn signal blinks very rapidly. It's because LEDs use less power, which mimic a burned out bulb, so it blinks rapidly. You will either need to install in-line resistors, or get LEDs that have the in-line resistors built-in, a decoder unit in-line or built into the LED itself, as Acey mentioned.What's hyperflash?
Oh man, this requires codes?It's when your turn signal blinks very rapidly. It's because LEDs use less power, which mimic a burned out bulb, so it blinks rapidly. You will either need to install in-line resistors, or get LEDs that have the in-line resistors built-in, a decoder unit in-line or built into the LED itself, as Acey mentioned.
No, not "codes", a decoder unit built in-line between the LED and plug, which is just a small box. It forces the light to blink a more normal rate than if there was no decoder or resistor.Oh man, this requires codes?
