iforyou
- Jun 22, 2017
- 6
- 152
- 155
- Vancouver, BC, Canada
- 2017 Honda Civic Type R, 2001 Honda S2000, 2007 Acura RDX
Warning - Long Post!
TL: DR - The CTR in completely stock form is a beast at the track. It can set very competitive lap times consistently. No overheating issue in cool weather. No brake fade.
CTR in Action (sorry I had another cam in the car but I forgot to turn it on...):
My friend in our EK following my CTR:
So I did 5 full sessions on Monday at Mission Raceway at BC, Canada. Each session was 20-25 min long so it was close to 2 hours of run time. Ambient temperature started at around 6C (43F) and reached 18C (64F) by the middle of the day.
My aim for this track day was to see what a completely stock CTR is capable of at this track. Overall, the car held up well without and warning codes at all. I was able to run faster lap times in the morning in my first 3 sessions with my personal best at 1:18 flat. Could've gone faster in that particular lap but right after the last corner I had to let off the throttle because a STi was in my way. For reference, the owner of the club who organized this track day told me a stock STi can only do 1:20 here. And that owner is far more experienced than me. There was also a Ferrari 458 Italia with RE71R who was doing just under 1:13. A C6 Corvette Z06 modded to 540hp with Nitto NT01 was doing 1:13. In the 2 after sessions, the front tires were giving up a bit and I could only get into low 1:19. Granted, my last session had a passenger.
The front tires obviously deteriorate in the afternoon though as you can tell from the photo below. The front tires simply "roll" over when cornering hard with the sidewall rubbing the asphalt. The club owner said this happened to his CTR too and that adjusting the tire pressure wouldn't help. The rims seem too wide for these tires and perhaps more camber would help. It could also be a tire design issue.
***Jeff, the owner of Temple of VTEC, mentioned that he put 35psi when the tires were cold and that should eliminate the tire issue***
Coming into this track day, my biggest concern was cooling issues. As mentioned, no error code was shown by the car. I guess the relatively cool temperature was a key factor. With that said, the temp gauge did go above the half way point when I was going all out. But it quickly went back to just below half way if I slowed down my pace for half a lap.
The brakes were excellent throughout the day, especially for this track which is known to be brutal to the brakes. I think there may be a tiny bit of brake fade but they were definitely confidence inspiring.
Front Right Tire:
Look at the sidewall of the front left tire:
Front Right Tire:
