josby
- Dec 11, 2015
- 24
- 866
- 567
- Central VA
- 2016 Civic Touring sedan
I tried to check for this tonight (yes, I had a friend drive while I did this lol):It was only when I added the DSP and amp that it sounded harsh - perhaps boosting midrange and tweeter.
The bottom line is through my DSP's AUX in (just to confirm I get a flat measurement from REW first). The rest is a pink noise WAV file played on the Civic headunit/amp, connected to the DSP via the front mids, front tweets, and sub. The DSP input EQ is adjusted to flatten out the wonky OEM curve (can't quite flatten it 100%). I set the DSP for just a basic 2-channel fullrange output with no EQ on the output and these are readings from the left RCA output.
The bottom is 0mph, then 70 mph with SVC off. Just 1/10th of a dB difference - probably slightly higher amp output due to the alternator putting out more voltage while moving. Basically no difference, as you'd expect.
The next three are at 70mph with SVC low, medium and high. 2 dB bump, 6 dB, and 9 dB respectively. But no change in the shape of the curve the headunit is outputting, except a little tweak down above 17 KHz. There's so little music content that high, and it's such a small change (especially with SVC on Low), that I can't see that being what you guys are hearing, though.
But, this was done with volume at 30, so the SVC bumps the effective volume setting to 32, 36, and 39 in that case. The headunit doesn't change the bass at any of those volume levels.
So I tried it at volume 15 also, where the headunit does add a bass bump. The SVC low/med/high would then push the effective volume setting to 17, 21, and 24, and the bass bump is decreased as the volume goes up in that range. Results:
So maybe that's what you guys are hearing - as SVC turns up the volume, the bass doesn't increase in volume as much as the rest does.
If that's the case, adjusting your gains so most of your listening is done above about volume 25 will probably allow you to keep using SVC without that problem.
Another possibility is SVC is changing the balance between left and right volume, which I didn't check, or that it's changing the balance between front and rear volume. I don't use the rear outputs for anything so I wouldn't catch that - not sure if you guys might be using both front and rear.
