I have 3 friends with Golfs, 2 of them are GTIs. They all say the same thing. "I love it, but I wish it didn't break so much."That's because reviewers don't have to live with them for the next three years and all that may entail.
The next 3 years aren't the issue. It's mostly going to be the 3 or 4 years after that.That's because reviewers don't have to live with them for the next three years and all that may entail.
But for people who don't mind working on their car, even a slight performance bump might be worth the trouble. That's why the review should be independent of that stuff. The review should only talk about performance then people can come to their own decisions about whether or not the hassle of worse reliability is worth whatever performance difference (if any).I have 3 friends with Golfs, 2 of them are GTIs. They all say the same thing. "I love it, but I wish it didn't break so much."
I'm 40k miles in on my 2016 Touring, and have had one infotainment flash update, and a few interior rattles. I'll take that over what they get to deal with any day.
Are any of them newer than a MKV? The MKVI after 2012 has been very reliable from what i have seen in my area. Many DD with high miles and no significant issues. The early 2.0TSI (2009-2012) had some issues with the BPV and the ignition coils after you tuned them beyond stage 1. Audi R8 coils are cheap ($20) and an aftermarket BPV (or the metal replacement) would cure the boost leak.I have 3 friends with Golfs, 2 of them are GTIs. They all say the same thing. "I love it, but I wish it didn't break so much.".
From experience I would suggest test driving the SI's handling and gear shift points/turbo lag. Biggest 2 things I'll think you'll want to consider. I truly miss my SI shifting. I am starting to get a hang of the shifting and even the turbo lag. I miss that the SI hardly lugged in 5th and 6th gear. You truly had to be going slow. The gears are also much taller on the GTI. I've just got used to it. Basically have to downshift 1 lower gear than the other gen. One would have to assume that the gearing would be very similar since Honda has gotten away from basically the motorcycle gearing and RPM's. I'm eager to hear impressions of how well the new SI handles and if there is a noticeable difference between the active dampers. Definitely test drive the new SI and try and soak in as much as you can. If you're coming from a 9th gen there are definitely going to be a few things you miss. But the biggest disparity that nags me is truly how well Honda executes the driving experience, especially with manual transmissions. Aside from all the little positives and negatives outside the driving experience, at the end of the day it is how well the steering, shifting, gearing and suspension that make the car. Also another factor to consider is I really wish VW offered DCC in the SE trim still. I could care less about all the other stuff like nav and other 'luxuries' that Honda fans usually aren't used to. I basically paid a $4200 premium for DCC. is it worth it? Can't answer that yet because the car out drives the capabilities of the OEM pirellis. Will that change after I get Michelin's? I'm 99% sure it will. And one more important thing that will probably be a deciding factor is EPA ratings. 32mpg SI combined vs 28mpg GTI combined. Having a hard time getting that and I haven't drove like my typical speed demon self. My other SI was 28 combined and I usually got 28-29mpg. So far I've been getting 25-27. Actually just shy of 27. And I've been driving like a wannabe hyper miler. Honda definitely has the rep for getting actual rated MPG and often times does better. Rated at 32mpg combined I'm quite sure people will get that ±1mpg for sure. Also quite sure peeps will be getting 35MPG easily. In VW's defense though, my commute changed about 2 mo that before I got it. Highway on the way in and city driving on the way home. My MPG was 27-28mpg after the change in my SI. I still got closer to 28 or better though. Wasn't surprised that Honda brought out a sporty compact that gets better MPG than many a base car. One more thing in VW's defense is the more research I do I still in awe of how easy it is to work on the Golf. Even more so if you have access to a lift. I could probably do 80% of minor fixes on my own without a lift and access to a driveway. That # probably jumps to 95% if you have access to a lift and are mechanically inclined. I've rarely had to work on a Honda but going from my long time mecbanic's comments, he does the work on Honda/Acuras often but says a lot of stuff is a pain the ass. Just something to consider. I am actually kind of envious. Kind of wish I had waited to see how the SI drives. Something tells me it will still drive well aside from turbo lag so the turbo lag part is a wash. Still loving the hell out of my Autobahn. The interior is awesome. I just sound dampened all 4 of my door and isolated the subwoofer. The sound went from top tier for an OEM sound system to low tier on an aftermarket custom install. But disregard that. Definitely check the steering, brakes, suspension and shifting. I'm biased towards the Honda being among the top of top tier transmissions paired with daily driving.
This was mentioned in another thread. Though it may be possible, I can't fathom a dealer allowing a test drive on an Si. Or multiple test drives. Those miles will add up and there's no way I'm purchasing a 60-80+ mile Si as I know what those miles mean. (thrashing)My dealer is saying their allotment is showing up next week, so I'll give it a good thrashing when I can!
Yes buying a new car is a very nice experience in and of itself. Getting one off the truck is even sweeter if you can swing it. When I ordered my Mustang, I got a call at 9AM on a Saturday from the salesman. He said "get your ass down here if you want to watch it come off the truck. I can't hold it on there much longer." Hungover as hell I got my ass up and was able to make it in time! 1.3 miles on the odometer!Yeah being "fresh off the truck" is one of my must-have requirements when I do buy this baby, which is within 2 months from today.
Nice! Never saw one actually off the truck; that was one hell of a cool sales guy you got there...Yes buying a new car is a very nice experience in and of itself. Getting one off the truck is even sweeter if you can swing it. When I ordered my Mustang, I got a call at 9AM on a Saturday from the salesman. He said "get your ass down here if you want to watch it come off the truck. I can't hold it on there much longer." Hungover as hell I got my ass up and was able to make it in time! 1.3 miles on the odometer!
Almost as equal was my 2003 Cobra. They had a few on the lot but most in the 30-40 mile range. Pretty low, but the salesman admitted they were all test driven. I asked if he had anything else coming in and low and behold in the back were 2 just delivered with all of the plastic. Never driven except off the truck and parked. We did a full once over and I took it home plastic and all with nothing removed! Once I got it home I couldn't believe how much plastic was on there! Took a while to get it all off but worth it!
I can see them having a "buy it, than drive it" policy with the Type R, but I honestly can't see it with the Si. For instance, when I bought my current Si HFP, I test drove it 3 separate times on a beautiful winding road with elevation changes, hairpins, etc. and definitely had the car at redline a bunch and put some heat into the tires and brakes. End of the day, if I'm not (within reason, of course) able to test drive the car in situations that I'm going to want to put it in, than they don't get my money. I need to see if the car fits me or not. My dealer gave me a long leash and closed the sale easily. Hell, when I drove the GTI the other day the salesman let me take out a Golf R afterwards to compare and had no issue with me beating on it for a while.This was mentioned in another thread. Though it may be possible, I can't fathom a dealer allowing a test drive on an Si. Or multiple test drives. Those miles will add up and there's no way I'm purchasing a 60-80+ mile Si as I know what those miles mean. (thrashing)
IF the Si's arrive on dealer lots like most other Civics, the car will have less than 5 miles. I've seen some with .9 miles. That is what I'd look for. I've purchased many new cars over the years and none had as low miles as Honda Civics. (I assume the rest of the lineup is the same?) Even my factor orders. There are tons of people on this board and elsewhere that don't need a test drive to purchase one.
Not saying it won't happen, but if I owned a dealership, there's no way I'd allow it. You buy then drive. Will be interesting to see what they allow with this one.
