VitViper
- Apr 28, 2015
- 43
- 638
- 1,992
- United States
- Lots
Initial testing of the DP at low boost (factory levels) showed about 8hp gained... but the boost as monitored by the dyno was about .5-.6psi higher which would account for the "gain". At 14.5psi of boost there was literally nothing to be found, ran the motor as hard as it could go and basically nothing changed. The turbo DID want to spool faster, but this is limited (controlled) by the ECU, so it didn't really get a chance to. So on a factory tune I can see the DP "making power" simply because boost might actually be a bit higher than the ECU is wanting because the ECU is calibrated for factory exhaust components (freer flowing exhaust == turbo wants to spool quicker and will make a tad more boost with the same "boost control" settings).
Since my clutch is hanging in by a thread I ran some higher boost pulls by rolling the boost in and was able to see about 260tq before the clutch wanted to slip -- and zero power difference on the top end, still the same 230-240hp as before. I'm working on an upgraded clutch so I can do a full test at high boost.
I'm a little disappointed but also surprised -- I suspected this motor really just needed good fuel and there may not be a flow restriction since the turbo (especially turbine) is soooo small in relation to the factory downpipe (even though it has a cat). With the stock turbo it may not be flowing enough to be backing up the factory DP... Once my upgraded clutch is ready I will get back with high boost (26psi+) mid range pulls as I think this is where the extra power (torque) and DP will help -- or with an upgraded turbo, coming soon as well .
Keep in mind I am on good fuel so my motor isn't ignition limited -- on 87 octane or varying forms of "premium" (the premium fuels do vary) the results may vary as the ign. limit of the motor may be different with the free flowing DP -- so the power should be found in the tune at that point.
That said the DP is a beautiful piece -- quality work as always from PRL and fit on the car like a glove. About a 2 hour install on our lift.
