1. Guest, see the CivicX Forum Rules and User Agreement before posting.  After reading click here to dismiss this notice →
    Dismiss Notice
1.5T PRL Motorsports Civic X 1.5T Product Development
Discussion in 'Engine / Exhaust / Transmission / Tuning' started by PRL Motorsports, Jan 26, 2017.
  1. JDM_DOHC_SiR
    JDM_DOHC_SiR Senior Member
    Rank:
    Apr 17, 2017
    485
    503
    Occupation:
    Government
    Eastlake
    2009 Civic Si / 2012 Acura TL / 2018 Civic Si
    Impressive CVT cooler there!!:thumbsup:
    PRL Motorsports thanked this.
  2. NeoDragons
    NeoDragons Senior Member
    Rank:
    Jun 19, 2016
    943
    743
    Occupation:
    Parts Stock Controller
    Guam
    2016 Honda Civic Sedan EXT
    Garage Profiles:
    whats that piece on the right? is that it the OEM CVT warmer?
    UberCivic and kshawn thanked this.
  3. OP
    PRL Motorsports
    PRL Motorsports Senior Member Elite Sponsor
    Rank:
    Jan 26, 2017
    316
    Featured Threads:
    762
    Export, PA
    2017 Civic Si, 2016 Civic EX-T
    That wouldn't be a bad idea, but it shouldn't be necessary unless the maintenance is due. We are expecting some fluid that will need to be added to accommodate for the added line and cooler, but we will addresss this when we get there.
    :thumbsup:
    We wish we could've had this available for you then as well! :(
    Pricing will be published in the next week or two once everything is finalized.
    Thank you, SiR! :headbang:
    Correct, these cars come from the factory with a CVT warmer, whereas we are replacing it with a CVT cooler. During initial testing, Hondata noticed that CVT trans temps were through the roof, so they briefly experimented with a similar cooler setup with success on their endurance car. Honda gave these cars a warmer for a reason, so we would like to collect data and see if the warmer's pros outweight its cons before making a cooling system without a warmer available to the public for street/daily driving. We have reason to believe that we will be fine! :)
    NeoDragons and Quicksipper thanked this.
  4. jeffbatt Senior Member
    Rank:
    Oct 1, 2016
    134
    40
    Boise, ID
    2016 Civic Touring Sedan, 2000 S2000
    Can you retain the warmer somehow? I live in a place that gets cold in the winter...must be there for a reason..
  5. cmwalton16
    cmwalton16 Senior Member
    Rank:
    Feb 12, 2017
    686
    679
    Occupation:
    VW Engineer
    Tennessee
    2017 Civic Si Coupe ABM, 2016 Civic Touring CBP
    Ahh stock "warmer" my bad, very interesting... we should see a great improvement then!
  6. OP
    PRL Motorsports
    Rank:
    Jan 26, 2017
    316
    Featured Threads:
    762
    Export, PA
    With this design we will not be retaining the warmer. As stated earlier, we will be testing to see how essential this warmer really is and outweighing the pros and the cons of the warmer and cooler. If we come across an issue or need, back to the drawing boards we go. Until then...
    We got around to dynoing our Project Snow White Si earlier today. While we were at it we decided to do some before/after runs testing our Stage 1 intake system. We never really anticipated this kit to be a big power maker, more or less a simple bolt-on mod for customers looking to improve aesthics and air flow. With that being said, we were rather impressed with what we came to find during testing.
    We recorded four dyno pulls with the Stage 1 Intake system. During the four 3rd gear pulls we noticed that the knock control value continued to drop, which shows an increase in efficiency, whereas the knock control value with the factory intake system is rather sporatic. As this knock control value decreases the ECU continues to add timing and allow the car to make more power. We began testing this morning with the stock intake when the temperature was in the upper 60's. These numbers and gains held consistent into the late morning when temperatures rose about 7 degrees Fahrenheit into the mid 70's. Our stock 10th Gen Civic Si made a best of 200 whp and 210 ft/lbs tq on our DynoJet.
    Here is a 3rd gear comparison of the stock intake system and our Stage 1 intake system. We chose to compare these runs because of how identical knock control values, coolant temps and air temps were (within +/-1%).
    Here is a 4th gear comparison of the stock intake system and our Stage 1 intake system. Again, these two graphs show identical parameters.
    With that being said, we managed to see mesaurable gains with our Stage 1 intake system in comparison to stock. Customers can expect a 4-9 whp gain without a tune by simply bolting in our high flow drop-in filter and silicone intake hose. We expect to see MUCH larger gains with our cold air intake system.
  7. shadow Member
    Rank:
    Jan 19, 2017
    40
    Philippines
    99 Civic SiR, 11 STI, 15 CRV, 16 Civic RS Turbo
  8. hawk02
    hawk02 Senior Member
    Rank:
    Nov 3, 2016
    751
    339
    Far away
    2017 Civic Hatchback Sport
    That's awesome to hear as I got the hose on with my AFE dry flow and felt and heard a difference and thought placebo but I guess not!!!!!
    PRL Motorsports and JDM_DOHC_SiR thanked this.
  9. hawk02
    Rank:
    Nov 3, 2016
    751
    339
    Far away
    Love it so far
  10. OP
    PRL Motorsports
    Rank:
    Jan 26, 2017
    316
    Featured Threads:
    762
    Export, PA
    :agree: We expected a somewhat audible difference in sound difference and small smaller performance gains (3 - 5 whp); This system was mainly intended to be more of a maintenance upgrade and cosmetic mod that gives minor gains at the same time. We couldn't be any happier with the results! :)
    Glad to hear it! :thumbsup:
    hawk02 thanked this.
  11. omigulay
    omigulay Senior Member
    Rank:
    Oct 18, 2016
    228
    117
    Vancouver, Canada
    2017 Civic Sport hatchback
    I still haven't gotten mine yet!:(
  12. OP
    PRL Motorsports
    Rank:
    Jan 26, 2017
    316
    Featured Threads:
    762
    Export, PA
    More updates! Our prototype is complete! We will be testing next week! All piping will come standard powdercoated textured black.
  13. JDM_DOHC_SiR
    Rank:
    Apr 17, 2017
    485
    503
    Occupation:
    Government
    Eastlake
    Can't wait to see how it performs an absolute work or art!!:thumbsup:... also waiting to hear more about the Cobra Race CAI as well ;);)
    PRL Motorsports and cmwalton16 thanked this.
  14. fastSI
    fastSI Senior Member
    Rank:
    Aug 30, 2016
    88
    Occupation:
    Parts Departement at Honda
    Trois-Rivieres,Quebec,Canada
    Honda Civic SI Coupe 2017
    Garage Profiles:
    Will you guys be making a Short Ram Version for the SI
    since im in Canada..Cold air wont fit
  15. davemarco Senior Member
    Rank:
    Jun 3, 2017
    170
    102
    New York
    2017 Civic SI Coupe (White Orchid Pearl), 2001 Honda Prelude (Premium White Pearl)
    I believe that @VitViper had tested the PRL Downpipe with the regular 1.5T EX-T, and determined that the gains would be very impressive, but that he was limited at the time by the electronic waste gate. Since he has since indicated that the new 2017 SI does not employ this boost target dampening below a certain speed (40 mph?), I was wondering how strong the effect on a 2017 SI would be?
