As most people will think omg i better put high octane in there.. Gotta be better since it costs moreMost engineers exposed to the public are told what to say by marketing, if they don't understand that they'll find one who does.
watch it again, he says it wouldn't make a noticeable difference. which 5-7hp really isn't a noticeable difference.All I know is that I saw a video last year that featured a Honda engineer (yes, from Japan), who said the engine was designed to run on 87 and that going with 91/93/94 wouldn't make any difference.
Sorry, but I tend to side with the professional from Honda here.
Not such a big benefit means they didn't want to let the cat outa the bag. It's 2016 guys. Almost new every car today benefits from high octane in some way. Not saying run it. It is awesome the 1.5T runs on 87 too.All I know is that I saw a video last year that featured a Honda engineer (yes, from Japan), who said the engine was designed to run on 87 and that going with 91/93/94 wouldn't make any difference.
Agreed 100%. Lol. I do once in awhile will run it maybe 1 in 10 or 15 tanks I will fill with Shell V-Power for the cleaning effect of injectors and combustion chambers. (does it work?). Who knows but I like to think so. It's only a one in 10 or 15 tanks I do this so doesn't hurt the wallet. And never get that low as the one poster did. Fuel pump needs fluid to keep cool and lubricated. You go that low it will shorten the life of the pump.Placebo on how it felt. Higher octane prevents knocking. It doesn't make your car faster/stronger.
The highly qualified engineers at Honda designed it to run on 87 Octane.
Don't waste your money on anything other than 87.
Yes advancing timing a bit you will want a 'slower' burning fuel. But I am interested as to see if they changed compression ratios. But yes I will agree if they changed the timing curve. Yes a higher octane will be needed.Very probable it has a more aggresive timing.
Hey this is my first post! So I am sorry if I am resurrecting an old thread or if I should start a new one.Yes advancing timing a bit you will want a 'slower' burning fuel. But I am interested as to see if they changed compression ratios. But yes I will agree if they changed the timing curve. Yes a higher octane will be needed.
Lol. Just checked. Same.....10.6. On both sport and regular Touring
per Hondata, any alteration to the ignition timing can have a big effect because it is very close to TDC, however when you run higher octane, the ecu continues to fight with its pre determined tables and it will limit boost. that's why it's best to get a custom tune for your car so you can fully take advantage of the higher octane. (also...from the post you quoted by @Farcry1010... octane doesn't actually burn any slower or faster however it can be more knock prone or resistant.) higher octane = knock resistance= more timing.Hey this is my first post! So I am sorry if I am resurrecting an old thread or if I should start a new one.
In my opinion I wanted to believe that the 87 octane was just as good and that 92 octane offered no performance enhancements, but in my opinion, the 92 octane was more fun to drive.
Use Case #1 ) Acceleration from a dead stop at a light seems to give a little extra "pop" and sound of the engine is more aggressive. This is in normal Drive mode, not Sport.
Use Case #2 ) Merging onto a highway from a low speed of 5-10 mph to 50 mph seems like I'm able to accellerate faster. Pushing the gas pedal with 92 seems to offer more acceleration without having to press the gas pedal as much as with 87 gas.
From the other posts, it seems that I should be using Shell or Chevron (no Chevron stations in my area) or some other Top Tier gas. I've been using Wawa, but intend to switch to Shell.
Am I crazy or is this a placebo effect? Is this the "timing" being adjusted so that I notice better performance?
Thanks!
UPDATE: I'm driving a 2017 Honda Civic EX-T sedan (4-dr Sedan w/ 1.5 turbo)
Higher octane does in fact burn slower btw. That's why it's less prone to knock. Especially in higher compression ratios. But why I was responding before because someone was posting that it does state on fuel door to use premium fuel on sport models and that poster said that it could be a more aggressive timing curve resulting in the need of higher octane. I confirmed sport models have the same compression ratios.per Hondata, any alteration to the ignition timing can have a big effect because it is very close to TDC, however when you run higher octane, the ecu continues to fight with its pre determined tables and it will limit boost. that's why it's best to get a custom tune for your car so you can fully take advantage of the higher octane. (also...from the post you quoted by @Farcry1010... octane doesn't actually burn any slower or faster however it can be more knock prone or resistant.) higher octane = knock resistance= more timing.
