Mishimoto Catch can for Si
556ALPHA
2017 Civic Si Coupe
I am curious to know the answer to the above question.
556ALPHA
2017 Civic Si Coupe
This is the question I am referring to that he asked...
“Why does the Civic Type-R oil catch can that you produce come with a boost check valve to prevent boost pressure being forced back into the block through the catch can yet the Civic 1.5L Turbo CC you make not come with a boost check valve?”
tanginaglaz
2017 Civic Si Sedan
UPDATE: I got in touch with Mishimoto regarding this issue. After much back and forth, I got the following reply: "As of now, we are doing our R&D for the Civic Si intake. Currently, the R&D team is running vehicles both with and without the check valve to determine if it is necessary for the final product. As of now, we have yet to reach a conclusion if these will be required on the Si catch can."
Sounds like they will be running tests on the Si in their shop.
Mugenkb1
Southern California
05 Acura RL, 16 Acura MDX, 17 Civic Hatchback Sport 6MT
Hmm, what about a non Si 1.5 turbo?
Mishimoto
New Castle, DE
2017 CTR #1254
Hello Everyone
We did extensive testing on both applications and determined that a check valve on the 1.5t application wasn’t needed. Check valves can be easily sourced if you feed one is needed in your 1.5t line.
We’ve had the 1.5t kit on our Si donor car since September with no issues.
Thanks
-Jake
hawk02
Far away
2017 Civic Si Coupe
Hello Everyone
Thanks
-Jake
So I can use the catch can I had on my 1.5t Sport HB on my new Si correct?
Mishimoto
New Castle, DE
2017 CTR #1254
Will this benefit the 1.5t that much?
Hey Doublestack00
We've found that many of the newer factory turbo engines generate some level of blowby. With that being said, our catch can is a great way to help counter this issue and prevent contaminants from re-entering your vehicle's intake system & engine. Generally speaking, this helps to increase engine longevity.
Thanks-Jake
tanginaglaz
2017 Civic Si Sedan
Hello Everyone
Thanks
-Jake
Thanks for the update! Had an OCC on my BMW E92 335i and I believe it was the reason why I didn't need walnut blasting.
Brian17Si
Brian
Hartford CT
2017 Honda Civic Si
I have to be that guy and ask. If this was an issue wouldn’t Honda put an OEM on from factory? I was going to do this on my previous car and people asked me that same question.
l15b7allturbo
San Diego, CA
2017 Honda Civic Si
Extra maintenance and if left neglected... you'll end up with all the blowby dumped into the motor. Also could freeze in very cold temps
