LX radio replacement thread
xcivicx
whycanogaparkofcourse.
19 SI coupe in black
Research has shown me that there is just about zip for the 2016 civic right now. IMHO for anyone who enjoys music, the base stereo is just no good.
to start i'm going to install a double din pioneer to replace the current pos.
Honda Civic 10th gen LX radio replacement  thread radiotrim_zpseedvfgui
note that there is a bezel thing around the top that is part or the original radio, brackets from the original transfer right over with little trouble. a third mounting point needs to be addressed. the resulting surface is almost flat so a bezel could easily be fabricated until a store bought could be had
next post wiring.......
xcivicx
xcivicx
at first i thought i might luck out and the previous connectors would work. not so. the pin lay out is the same, the difference is in the way the male and female couple. the wire layout seems different also.
until a ready made adapter is avail, i may have to hard wire it as a last resort.
here is a couple pic of the connector that handles most every thing.
Honda Civic 10th gen LX radio replacement  thread wireb_zps1lzjodvw
Honda Civic 10th gen LX radio replacement  thread wirea_zpsmbje8nee
Wire color 24 pin connector
1 black
2 dark blue
3 white
4 yellow
5 brown
6 white
9 light blue/silver
11 pink
13 brown
14 light green
15 light blue
16 grey
17 violet
18 yellow
19 light blue
22 red
23 dark blue
this connector seem to handle speakers, power, steering wheel controls maybe more.
wire color speakers (base lx)
front left pink and gray
front right brown and yellow
rear left light blue and red
rear right dark blue and white
question right now is the dupe colors? and do the speaker wires change color between the speaker and the head unit.
bhorn
Mobile, AL
'16 Civic EX HS Sedan
This thread is going to make me regret getting an EX... :oops:
xcivicx
xcivicx
heres the back of the radio
Honda Civic 10th gen LX radio replacement  thread backofradio_zpsa4txntyt
from left to right whit antenna connector then the camera wires and, then usb, finally the power and speacker wires
next step is to figure what wire does what or wire tracing. will try to post more useful pics until the.
Honda Civic 10th gen LX radio replacement  thread radio%20back_zpsikhcrqyc
back of radio connectors disconnected
Honda Civic 10th gen LX radio replacement  thread antennaconnector_zpsqbssbcgt
antenna and usb connectors
bhorn
Mobile, AL
Hmm, a regular old USB type B connection. That's interesting.
CE1_nobling
Spring,TX
2016 Honda Civic LX 6sp , 1997 Honda Accord EX Wagon , 2005 Chevy Silverado 2500HD CrewCab 6.0
Anyone have Honda online access to a wiring diagram for the LX radio ?
timothyjay
Jacksonville, FL
2016 Honda Civic Touring
Nice! Which Pioneer NEX did you get? My friend got the 4100NEX on his Tacoma to replace his radio and it's amazing. I was considering on getting it as well for my '06 Civic until I got my '16.
xcivicx
xcivicx
its the avh 5800 bhs, no navigation. but can add later for $$$. when i went to the local car stereo stores and heard even there demos sounded so much better than the base lx radio, i just had to jump in. bezel or not wiring kit or not.
wiring update found only the hot ground and acc.
plus the connector i bought doesn't exactly mate the best. going to investigate the factory manual.
xcivicx
xcivicx
more fun. went to check out the honda manual to maybe get the wiring diagram. alas i don't meet the system requirements. must use 32bit internet explorer 7 or above? how many have 32 bit machines nowadays. i do but only IE 6 and cannot find 7.
mrdarling
CT
05 Civic EX Coupe
Glad to see your making progress! Keep the info coming! You're the pioneer of this so far.
mrdarling
CT
05 Civic EX Coupe
How difficult was it to get the cover holding the stereo in off? Did you have to remove any other paneling to get it off?
xcivicx
xcivicx
once the ac controls are removed and the two screws that hold the radio in, the radio will just pop out. it may take a little force but not that much, there are 6 other points that need to be pulled out. grab from the top corners and give a crisp pull. there are four small philips screws that hold the rear of the bezel on, use the proper size. or if needed i see that part is about $20. i'll be postin an update real soon
edit did a rough install and i musssssst tell you.........
replace that factory radio as soon as you can even with a cheapie.
maybe final update to follow with all details.
xcivicx
xcivicx
sorry folks going to have to put off further updates for a bit as i want to finish up with the install, it sounds that good. even with the stock speakers. 85% as good as my home sys. but in the mean time the connector i bought will NOT work at all, tough the parts from it can and were used. this is only the most basic installation and gives me only the most basic of the head units features at this time. some of the head units features are locked and needs further inputs to unlock them, such as parking brake and reverse inputs. i'll do my best for pics.
mrdarling
CT
05 Civic EX Coupe
Understood. Please fill us in once everything is finished. MY LX (manual) gets delivered in April and I'm really hoping that I can get the new stereo working! As of now, your the only person I know of that has made an attempt.
