16civicFLA
- Apr 15, 2016
- 7
- 90
- 61
- Orlando, FL
- 2016 Honda Civic EX-TL, 2016 Honda Pilot EX-L
- #31
Invidia N1What kind of exhaust
It's comes with new bolts but the factory studs you have to hammer outI ordered mine and it should be here this saturday. So the stock bolts you have trouble with? The Invidia Exhaust came with those so that you can replace them or you had to buy it again?
Is there a new gasket between the new exhaust and the stock pipe or there is already one in the stock system that I need to reuse when I put the N1 in?It's comes with new bolts but the factory studs you have to hammer out
Most exhaust system comes with new gasket but if not I'm sure you could reuse the stock oneIs there a new gasket between the new exhaust and the stock pipe or there is already one in the stock system that I need to reuse when I put the N1 in?
I just finished installing mine today. Taking those 3 nuts out was hard but other than that it was not that bad. But after running the car for like an hour or so there was a burning smell coming from the exhaust along with the fumes. Did you have that initially since its a new exhaust or did I do something wrong. @16civicFLA @PRO CivicHere is a picture on how it sits. Sound clip will be up next.
its normal. the metal has a coating of oilI just finished installing mine today. Taking those 3 nuts out was hard but other than that it was not that bad. But after running the car for like an hour or so there was a burning smell coming from the exhaust along with the fumes. Did you have that initially since its a new exhaust or did I do something wrong. @16civicFLA @PRO Civic
So it will eventually go away right?its normal. the metal has a coating of oil
Planning to do one today or maybe tomorrow and will share it.How about a video
Thanks for posting that info. Some factory bolts can be especially tough to remove. I'm glad you figured this out. We'll be doing an install video in the near future and I'm sure we'll run into the same issue.So my buddy and I decided to try again to install the exhaust instead of over the weekend. What a success! Those bolts in the first picture are tack on and you will NEED a hammer to remove them. We remove that piping and gave it a few good hits and boom they came right off! After that it was a piece of cake installing the rest! The Invidia exhaust sounds amazing! Definitely recommend it and can't wait to get my custom tune done! I am going to get around to post pictures of the car just waiting to install my BC coilovers and wheels over the weekend!
The drop in MPG is most likely due to driving style (i.e. you're accelerating more now). The exhaust should not lower mileage under normal driving conditions.Yes I have noticed a decrease probably due to it not being tuned with the exhaust. Don't want to spend the money on a tune till a downpipe releases
The bolts are actually welded in at 4 points making it hard to take off. But hitting it at an angle from the sides couple of times pops it right off. It takes a little time and patience but it does come off eventually.Thanks for posting that info. Some factory bolts can be especially tough to remove. I'm glad you figured this out. We'll be doing an install video in the near future and I'm sure we'll run into the same issue.
