1. Guest, see the CivicX Forum Rules and User Agreement before posting.  After reading click here to dismiss this notice →
    Dismiss Notice
Featured How to change brake pads on the new Civics - VIDEO!
Discussion in 'DIY guides and requests' started by dominican, Aug 9, 2017.
  1. dominican
    dominican Enthusiast YouTuber
    Rank:
    Nov 28, 2016
    230
    Featured Threads:
    201
    Occupation:
    YouTuber
    Pennsylvania
    1997 Honda Prelude, 2002 Honda S2000, 2011 BMW 335d, 2017 Honda Civic Hatch WOP Sport M/T
    Garage Profiles:
    So after searching this forum, I did not see a tutorial on how to change out the brake pads on the new Civics. I also noticed there are still no upgraded rear pad options for our Civics (unfortunately), but I hope that will change soon...
    Anyway, here is a video I made on how to change the brake pads on our new Civics.
  2. CobraCommand
    CobraCommand Senior Member
    Rank:
    Jun 28, 2017
    104
    97
    NS, Canada
    2017 Canadian Civic LX Sedan
    Nice video and +1 for using a torque wrench, but a few recommendations from someone who has changed brakes for a living:
    • You should always break lug nut tension with the wheel on the ground then lift and remove the nuts fully.
    • Clean the caliper with brake cleaner to get all the brake dust out before putting new pad in, that new grease will hold it in there and cause noise down the road.
    • Take out the caliper slide bolts and clean / lube them with silicone lube (silicone won't hurt the rubber boots - I like permatex)
    • If you're going to use a c-clamp to push the piston back in then do NOT ever just push the clamp into the piston, use the old brake pad between the c-clamp and the piston so it puts even pressure across it.
    • I'm super picky about always getting new rotors with brake changes but it's not really needed (but they are so cheap you may as well) or get them measured / turned at a shop.
    • Bungee cord or wire to hang the top of the caliper after removing it will help because if it falls it may rip the brake line and that's a pain that can be avoided easily.
    Since you track the car you'll be changing the pads quickly anyways, but for anyone who is just doing this to a commuter then i'd recommend checking out ChrisFix's brake change video.
  3. Rickmeister 48
    Rickmeister 48 Senior Member
    Rank:
    Jan 31, 2017
    234
    81
    Newark De
    2017 civic ex-t
    Garage Profiles:
    Cool video, I'd like to add that I find it way easier to compress those pistons if you remove the lid to the brake fluid reservoir,I put a paper towel over it to keep dirt out, then always check the fluid level after all the new pads are on.
    NT413, Design and dominican thanked this.
  4. Design Senior Member
    Rank:
    Sep 28, 2015
    2,099
    Featured Threads:
    1,692
    Southern California
    09 MS3, 17 ABM Si Sedan
    That or crack the bleeder screws to prevent reverse flow. I find that backing the fluid up the lines tends to soften the brake pedal feel a tad, thanks in part to the sensitivity of the ABS actuator. That and the risk of introducing contaminants from the caliper bore.
    OP, thanks for confirming that the rears don't require a CPU (another reason to choose Honda over VW lol). They look very similar to the Mazda 3 rear caliper design. And I think the brake tool kit from Harbor Freight might work (someone will have to confirm).
    Banshee, augustus and Rickmeister 48 thanked this.
  5. OP
    dominican
    Rank:
    Nov 28, 2016
    230
    Featured Threads:
    201
    Occupation:
    YouTuber
    Pennsylvania
    Garage Profiles:
    That'll definitely work, it's a pretty standard size. Better than that damn cube I was using!
    Design thanked this.
  6. ch3390 Member
    Rank:
    Sep 27, 2016
    United States
    Honda Civic 2016 Sedan EX Turbo
    I recently installed the same front brake pads you used in the video, my question is are yours noisy at all? I can hear mine squealing and I don't know if it's normal. Any way to fix this? I've never changed brakes before and that was my first time, I basically did everything you did in the video. As @CobraCommand mentioned should I just lube them and maybe the noise will go away?
  7. OP
    dominican
    Rank:
    Nov 28, 2016
    230
    Featured Threads:
    201
    Occupation:
    YouTuber
    Pennsylvania
    Garage Profiles:
    Mine haven't been noisy at all, you used the HPS pads? Just make sure you lube the pads up nicely. If you got more aggressive pads, they WILL squeal, no matter what.
  8. ch3390 Member
    Rank:
    Sep 27, 2016
    United States
    I got the HWS, I'll give it a try tomorrow to see if it helps. Thank you!
  9. OP
    dominican
    Rank:
    Nov 28, 2016
    230
    Featured Threads:
    201
    Occupation:
    YouTuber
    Pennsylvania
    Garage Profiles:
    You probably meant HPS. Check pad orientation as well, make sure they are where they are supposed to be.
  10. fjrman Senior Member
    Rank:
    Feb 12, 2017
    91
    37
    Tennessee
    2016 Civic 4 door LX with CVT
    You may be able to push the front pistons in with your fingers if you open the bleed screw and let the excess fluid bleed out through a plastic tube.
    Brake fluid is inexpensive. By adding new fluid to the MC reservoir you will be lowering the boiling point of the fluid.
  11. coo1rim
    coo1rim Senior Member
    Rank:
    Feb 14, 2016
    261
    64
    Occupation:
    driver
    toronto
    1998 civic, 2006 yaris, 2008 rav4, 2012 carmy, 2017 Civic LX
    Thanks for making look easy. I almost want to do it myself, but given the discounts my mechanic gets on parts and he only charges about $50 to do the job, I'll prob take the lazy way out.
  12. OP
    dominican
    Rank:
    Nov 28, 2016
    230
    Featured Threads:
    201
    Occupation:
    YouTuber
    Pennsylvania
    Garage Profiles:
    Happy to help, if your mechanic offered the same to me, I would do that as well. :respect:
  13. Froz3nTundra Senior Member
    Rank:
    Apr 7, 2017
    598
    434
    US
    Hatchback Sport 6MT
    I watched the section on the fronts, they are the same design as the 8th gen so anyone that has worked on those it should be an easy task. I typically get 100k miles out of pads/rotors so I don't end up changing them very often but it's good to know it will be familiar territory when I need to change these.
  14. CivicLX2016
    CivicLX2016 Senior Member
    Rank:
    Jul 11, 2016
    938
    536
    NJ/PA
    2016 Civic
    Garage Profiles:
    Really appreciate the video, man!
    I usually have the pros do these installs, but with this video and other videos out there, I think I will do this install on my own.
    Thanks again!
  15. d1zguy
    d1zguy Senior Member
    Rank:
    Apr 6, 2017
    554
    227
    VA
    17' SI Sedan
    Those brakes looked terrible. Almost as if the car were 5 years plus old
    CivicLX2016 thanked this.
