Apeks
- Mar 11, 2016
- 4
- 86
- 90
- Canada
- 2002 Civic SiR, 2017 Civic Si Sedan(MSM)
Check it out:
https://www.hondata.com/news/blogart43
"Hondata is the world leader in tuning Honda engines and have many world records to prove this. Every map listed here has been comprehensively tuned for fuel, ignition and boost.
Listed here are dyno plots of several of the many base maps provided with the FlashPro.
How the FlashPro will perform on a stock Civic Si ? The answer is superbly!
With a 100% stock Civic Si Turbo you will benefit from:
I couldn't copy the dyno graph it appears to be a dead link right now.
- 27 HP and 40 lb-ft torque
- Improved turbo spool
- Raised boost limits
- Better throttle response
- Better mid range power and torque
- Removed speed limit
- No change in part throttle fuel economy
- World class datalogging - which will teach you a lot about your engine.
- Dotted green line stock Si. 205 hp 235 lb-ft torque.
- Solid green line Hondata +6 psi reflash. 233 hp 258 lb-ft torque"
